Thread: Water temp warning light flashing from cold - 98 Polo 1.4 auto
  1. Water temp warning light flashing from cold - 98 Polo 1.4 auto
    Troops,
    I used the Polo (1998, 1.4 auto, 93,000miles) yesterday and it drove fine, no problemos. I started it up from cold this morning and as I was getting my seatbelt on/tunes sorted etc, the water temp warning light started flashing. I don't think it's out of coolant (two weeks ago it was full), and I don't think there's a head gasket problem, so I was wondering whether it could be the water pump, or a thermostat playing up? (in addition to dodgy connections maybe?) Yesterday, I drove along some muck covererd roads in the rain, and I wonder if maybe some muck has spashed up and affected a sensor maybe?
    Any ideas?
    Anyway the light was flashing this morning, so I turned off the engine and used the Clio instead. I'll do some more checks tomorrow. Is it dangerours to the engine to drive the car to a garage with the temp light flashing?
    Many thanks,
    g
  2. Re: Water temp warning light flashing from cold - 98 Polo 1.4 auto
    Jan 2009
    I've had this too on my wife's 2004 Polo 1.2.
    The last couple of days were below freezing temps and the temperature warning light came on from cold. I swichted the engine off after 2 mins and on again, the light disappeared.
    This happened yesterday and once before, basically when engine is started from cold in freezing temps.
  3. Re: Water temp warning light flashing from cold - 98 Polo 1.4 auto
    Feb 2009
    Can someone has similar problem and any suggestion how to solve this ?
    (ps i'm having same problem, on cold on my Mk7 polo flashes temperature light, and beeps 3 times)
  4. Re: Water temp warning light flashing from cold - 98 Polo 1.4 auto
    Lancashire
    I had the same with my wifes Polo. Changed the header tank, no more problems and it only cost about £14.
    Bilibong the Grumpy
  5. Re: Water temp warning light flashing from cold - 98 Polo 1.4 auto
    Not sure if its relevent - had the same on 9n polo, turned out there wasnt enough anti-freeze in the mix...
    If you can get a sample test it in your freezer to check if the ratio of water to anti-freeze its ok!
  1. Glow plug warning light flashing.
    By Nebooaw in forum Passat - Archive Topics
    Last Post: 06-07-2007, 07:37 PM
  2. Polo oil light flashing at switch-on
    By spockley in forum Polo - Derby - Lupo - Fox
    Last Post: 20-04-2007, 09:50 PM
  3. A6 running cold but temp warning ??
    By sumbuddy in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 12-12-2006, 03:50 PM
  4. Oil warning light flashing intermittantly
    By magicmk in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 11-10-2006, 09:46 PM
  5. Golf MK3 Coolant Level & Temp Warning light
    By andyc567 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 19-09-2006, 05:13 PM
