Thread: Talking of glove boxes.
Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. Re: Talking of glove boxes.
    Well that makes a nice change, I removed the complete glovebox and found the faulty damper, I removed it prised it apart and smeared the rubber seal with silicone grease. Now it works as good as new.
  2. Re: Talking of glove boxes.
    Dec 2008
    @classiccarguru1
    Hi Guy's,
    For info you can get at the damper by unclipping the side panel on the end of the dash when the doors open. Takes 2 seconds.
    As for the door, use a small hinge pin remover, if you dont have one, small long nose mole grips and a toffee hammer will do, you'll need to unclip the side panel as above to disconnect the damper also.
    The door can be removed in 2 minutes with the right tools.
    This drastically shortens the task, as if you take the whole glove box out you have to think about the air bag switch, cd changer and power to the lights.
    Kind regards
    D
  3. Re: Talking of glove boxes.
    Jun 2008
    Marmitehampton
    Remove the battery -ve terminal to avoid airbag errors if removing the glovebox. No harm will be done.
    You will have to recalibrate the one shot window function by winding them all down and then back up again.
    You may also have to resynch the remote function of the keys by putting the key in to the ignition, turning it on then off and within 5 seconds locking the car with the button on the key. Do this for each key.
    Much easier than having to go to the $tealer because of an airbag light, though.
    2007 Audi A4 2.0 TDI 140PS | S-Line | BOSE | Volterra Leather
    Retrofitted | RNS-E | SDS | Bluetooth | Cruise Control | Parking Sensors | Arm Rest | DIS
  1. TDI tuning boxes
    By will95 in forum Golf MK4 - 1999 - 2004
    Last Post: 23-04-2008, 02:30 PM
  2. Talking torque
    By torquer in forum New Member Introductions
    Last Post: 13-03-2008, 10:40 AM
  3. GPS not talking to nav plus
    By sdb in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 07-03-2008, 04:28 PM
  4. Talking Heads
    By Dan3A4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-01-2008, 11:22 PM
  5. Talking Heads
    Last Post: 19-01-2008, 10:51 PM
