Thread: 17705 fault code??? Help please?!
  1. 17705 fault code??? Help please?!
    Dec 2008
    . My a3 1.8t quattro has a fault code on the ecu what does this refer to and how can it be fixed. Symptoms are chuggy idle and ride feels like coil pack???
    Someone help please
    qboy
  2. Re: 17705 fault code??? Help please?!
    Southern County Softy
    20 Post(s)
    Taken from the Ross-tech wiki
    Possible Symptoms
    Power Loss
    Possible Causes
    Leaking hoses and/or pipes between components
    Check Boost Pressure Control Valve (N249)
    Possible Solutions
    Check hoses and/or pipes between components
    Check / Replace Boost Pressure Control Valve (N249)
    Check / clean Throttle Valve, do Throttle Body Alignment
    Special Notes
    Did anyone fitted an extra (wrong) dump valve?
    A4 2.5 tdi QS (mapped)
  3. Re: 17705 fault code??? Help please?!
    notts
    Possible Symptoms
    • Power Loss
    Possible Causes
    • Leaking hoses and/or pipes between components
    • Check Boost Pressure Control Valve (N249)
    Possible Solutions
    • Check hoses and/or pipes between components
    • Check / Replace Boost Pressure Control Valve (N249)
    • Check / clean Throttle Valve, do Throttle Body Alignment
  4. Re: 17705 fault code??? Help please?!
    Dec 2008
    hi.
    thanks for the reply. Just had it remapped. The guys there said that the fault code was n249 but was also saying open loop in this area. they checked the sensor on the boost control this was plugged in. We removed the code and it appeared again. Guttted really cos not geeting a benfit from the remap with this crappy boost loss!!!
    They said some of the wires in the engine bay had already been hacked into looks like they had a multimeter on it
    Is their any mechanics in the manchester vicinity that can help and wont rip me off???
    cheers
    Mike
  5. Re: 17705 fault code??? Help please?!
    Jan 2009
    Waterlooville, Hants
    I had this on my Golf Turbo and it turned out to be a knacked dump valve, the originals can be a little fragile. I replaced mine with a Forge 007 and never got it again.
    Matt
    http://www.mk4GTIturbo.co.uk
    2007 Passat TDI Sport DSG : 2000 Polo : 2001 Caterham Superlight
    Gone but not forgotten : ex 2006 Octavia vRS : ex 2001 GTI Turbo : ex 1987 GTI 16v
  6. Re: 17705 fault code??? Help please?!
    Norfolk
    The fact that the idle feels lumpy suggests an air leak. This culd be the contol valve but I would look for a cracked/split pipe.
  1. ABS Fault, have fault code readout....
    By nemeth782 in forum Golf MK4 - 1999 - 2004
    Last Post: 30-08-2008, 12:15 PM
  2. TT180, fault code 17705, help please.
    By dave635 in forum TT - 8N Forum - 1998 - 2006
    Last Post: 07-07-2008, 03:41 PM
  3. the old 17705 fault code
    By doc2000ad in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 30-05-2008, 04:47 PM
  4. Replies: 0
    Last Post: 15-01-2008, 01:07 AM
  5. fault code 17705 mk4 golf gti petrol aum
    By gticraig in forum Golf MK4 - 1999 - 2004
    Last Post: 19-12-2007, 11:08 AM
