Thread: Radio Problem in A4 Cab '04...
Results 1 to 8 of 8
  1. Radio Problem in A4 Cab '04...
    Aug 2007
    I have a '04 Cab with the standard fitted radio (I think it is Concert). Recently, when it has been, really cold over night the radio fails to pick up FM staions in the morning, but after the interior has warmed up a bit it starts working. Today it's not working at all, but now on FM and AM stations.
    It turns on and the built in CD slot player works. The station "scan" goes through the entire FM range and does not pick up a single station. Likewise on the AM stations.
    Is there some tool(s) I can buy to remove the radio to make sure it not something silly like a lose connection?
    If I do have to replace it, how much would a replacement Audi radio be?
    Can I fit non Audi radio/CD, (the slot seems the wrong size to me)?
    If I fit a non Audi Concert radio/CD will the dash info stop working?
    Thanks.
  2. Re: Radio Problem in A4 Cab '04...
    Southern County Softy
    20 Post(s)
    Check for broken wires by the boot hinge.
    A4 2.5 tdi QS (mapped)
  3. Re: Radio Problem in A4 Cab '04...
    Dec 2007
    Quote Originally Posted by ChrisPovey View Post
    Thanks.
    iv had the same prob on a few audis and now on my currant cab its either the aerial amp oor the wires as kite says my wires are ok so defo the amp and im not payin silly prices for 1 im gona either fit a power aerial in the front screen trim or a shark fin on the boot goin more way in the screen trim tho you can fit after market stereo ull need wireing and a face plate look nice an neat the dash wont work
  4. Re: Radio Problem in A4 Cab '04...
    Aug 2007
    Thanks both of you.
    Where is this aerial amp?
    How can check the aerial wires? Are they in the boot door itself?
  5. Re: Radio Problem in A4 Cab '04...
    Dec 2007
    its in the boot lid take cover off its on the left hand side 3 plugs go in to it the wires u need to check run through rubber from boot to car there known to snap
  6. Re: Radio Problem in A4 Cab '04...
    Aug 2007
    Ok. Sounds like a job for between Xmas and New Year!
  7. Re: Radio Problem in A4 Cab '04...
    Aug 2007
    It started working again over xmas, but has since died again. I get occasional busts of the station, but mostly static.
    Are there any guides, instructions etc on how to remove the boot cover as I cannot see any screws or bolts holding it on?
    Thanks.
  8. Re: Radio Problem in A4 Cab '04...
    Dec 2007
    Thanks.
    remove the warning triangle so under there and a cross head just in the handle wen removed just pull at it and it will unclip
    to check wires u need to be checking down the rubber between car and boot lid
  1. Please Help Fm radio problem
    By ben0069 in forum In Car Entertainment
    Last Post: 16-08-2008, 05:06 PM
  2. radio problem
    By rayray in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 13-02-2008, 11:30 PM
  3. Radio Problem
    By davidbed in forum Golf MK3 - 1993 - 1999
    Last Post: 19-01-2008, 11:40 AM
  4. radio problem
    By jrw in forum Audi A3 - Archive Topics
    Last Post: 06-09-2007, 05:23 PM
  5. 98 A4 Radio problem.
    By glenniosaurus in forum Archive posts
    Last Post: 29-06-2006, 05:05 PM
