Thread: Judder when pulling away
  1. Judder when pulling away
    Dec 2008
    Hi
    Recently got an audi 80 1.9tdi avant and am very pleased with it, but!
    On pulling away in first or reversing the engine seems to judder fairly violently! Causing the whole car to shake!
    I am assuming engine mount or gearbox mount?
    Or would there be another cause?
    It doesn't do it if your at say walking pace in second and pull away, only first.
    How do i actually check the mounts as they are £40 ea so want to do the right one?
    Thanks in advance, need to sort this as it spoils what is a very smooth car.
  2. Re: Judder when pulling away
    Pembrokeshire
    22 Post(s)
    apply handbrake with car on firm level ground. lift bonnet. get an able assistant to sit in the car, engine running. put into first gear and gently lift clutch, while you stand at the SIDE of the engine bay and watch the engine. repeat in reverse gear, looking for any lifting of the engine. be careful to have nothing in front or behind car, as if the car does move it can get awfully complicated, hence standing at the side. also jack car up and check wishbone bushes for movement. get a lever in behind the bushes where they join the subframe to check for movement. also check the 4 subframe mounts.
  3. Re: Judder when pulling away
    Dec 2008
    All wishbone bushes just replaced as were sub frame bushes as they were mot failures before i got it and i fixed it up. Will check engine mounts as described. Cheers
  4. Re: Judder when pulling away
    Dec 2007
    8 Post(s)
    Quote Originally Posted by falcodub View Post
    If when you check all engine/gearbox mountings and if you find
    them ok here is a tip to try (not a joke) spray a few shots of wd 40 in to inspection hole on top of gearbox towards centre of clutch
    I have tried this in the past and found improvement in judder
    problem. It does return after a while. Only theory here is clutch
    disc sticking on splines and helped by lubrication
    Another problem may be oil from turbo oozing on to drivers side engine mount making rubber soft
  1. Ive Fixed My A4 Tdi Judder At Last Please Read If You Have A Judder
    By justin@justinwa in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 23-11-2009, 08:32 PM
  2. Question Pulling Apart
    By alanrig in forum Golf MK4 - 1999 - 2004
    Last Post: 03-10-2008, 01:53 PM
  3. Please Help Judder when pulling away in 1st
    By Froggy_130PD in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-08-2008, 12:58 PM
  4. Question Judder on pulling away
    By agreen0 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 04-08-2008, 12:50 PM
  5. Help please - Stalling when pulling away - TDi
    By TimS996 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 24-09-2007, 01:00 PM
