Thread: Polo 9N 2007 blinker wires for remote locking
  1. Polo 9N 2007 blinker wires for remote locking
    Dec 2008
    Frankfurt, Germany
    Hi all,
    I have now read quite a bit on this forum and elsewhere how to upgrade to remote locking and have also bought a generic kit. Actually the guy who sold it on ebay said it was for a Polo, but there are no sockets in the package, let alone car specific. Only a socket to connect to the main unit, from there on i seem to be on may own. But before sending it back, i thought id give it a try. Considering the unit costed 18EUR, ok fine ill put it in myself
    I understand i need a 680Ohm resistor, no problem.
    What I am wondering however, is where i find the connectors to the blinkers? Its not the end of the world, but id like to have the flashing on the car when locking/unlocking. Where is the best place to connect into?
    Are the blinkers also a negative trigger?
    Any tips, help or tricks would be much appreciated.
    Alex.
  2. Re: Polo 9N 2007 blinker wires for remote locking
    134 Post(s)
    2018 Post(s)
    The colour code of the turn signal wires is black/white (left) and black/green (right). These come from the column switch and go to the onboard supply control unit. I have never powered the indicators on a 9N with its onboard supply control unit so I don’t know if it would get upset by this.
  3. Re: Polo 9N 2007 blinker wires for remote locking
    Dec 2008
    Frankfurt, Germany
    Thanks Crasher, would you also know where this control unit is in the car? I guess it would be cleaner to find the unit and connect on its socket. Id also have to do some testing and would hate to cut the wrong wire, so better to go on the socket of the control unit.
  4. Re: Polo 9N 2007 blinker wires for remote locking
    134 Post(s)
    2018 Post(s)
    The unit is under the relay plate above your right foot.
  5. Re: Polo 9N 2007 blinker wires for remote locking
    Dec 2008
    Frankfurt, Germany
    Thanks again Crasher much aporeciated. I gave it a shot today, found the unit and the cabels too. I have now two other problems:
    1. When the key is not in the ignition, the direction lights dont come on, instead the parking light comes on and the light warning ( beeps when you forget to turn off the light ). Only with the key inside the direction lights come on. Maybe I could instead use the connection to the warning lights. They work even without the ignition key.
    2. This is the bigger problem. I cant get the cover of the drivers door opened. It sounds rediculous, but I have tried everything without breaking something. It seems to be stuck somewhere in the middle of the door where the handle is, but cant find any traces of any screws or anything.
    Any ideas?
  6. Re: Polo 9N 2007 blinker wires for remote locking
    134 Post(s)
    2018 Post(s)
    1. That is correct, parking lights are initiated by the ignition switch going to the P position. This will not affect the system you are fitting, it provides its own flash function, it does not operate the flasher relay, well none that I have ever fitted anyway.
    2. The screws are under the switch/pull trim.
  1. Please Help 03 Polo 1.4 Remote Central locking?
    By tony1ant in forum Polo - Derby - Lupo - Fox
    Last Post: 06-02-2009, 11:04 AM
  2. 1997 Polo 6N remote central locking
    By Andrew White in forum Polo - Derby - Lupo - Fox
    Last Post: 20-12-2008, 01:15 PM
  3. 2000 Passat blinker
    By iwrk4u in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-09-2008, 09:45 AM
  4. Question Upgrading Polo central locking to Remote
    By Corsadad in forum Polo - Derby - Lupo - Fox
    Last Post: 27-07-2008, 09:18 PM
  5. Help installing remote for central locking on R reg polo 1.6l
    By ukeminem88 in forum Polo - Derby - Lupo - Fox
    Last Post: 22-07-2007, 02:29 AM
