Thread: HELP - Where is the oil filter on 115 PD engine?
Results 1 to 10 of 11
  1. HELP - Where is the oil filter on 115 PD engine?
    Feb 2007
    Leicester
    I am in the middle of an oil change and i can't workout where the oil filter is onmy 2001 A4 Avant with 115bhp PD engine. Can anyone help me out? I would really appreciate it!
    Oct 2005
    Lutterworth
    Under the engine cover at the RHS (looking from the front) of the head.
    72mm-ish socket to unscrew the top.
    Passat Estate 2002 PD130
    Passat 1.8SE 1998
    Feb 2007
    Leicester
    Thanks for the reply. I was looking at the right thing then but I couldn't get it undone. It didn't seem to me that it had been opened recently either whixh is a bit worryng when it was meant to have been recently serviced. Can you just tell me, are they done up quite tight? Thanks.
    Oct 2005
    Lutterworth
    The plastic cap gets a good grip on the metal.
    When you put it back on just nip it up gently. The O-ring provides the seal.
    Passat 1.8SE 1998
    Feb 2007
    Leicester
    Thanks for your help. I'll have to get down to the local motor factiors (Euro Car Parts) to see if they have the 72mm socket.
    May 2006
    Exmouth, Devon, UK. Drives Bonkers Fabia Diesel. Has full VCDS
    Its a 32mm socket on mine - 72mm sounds massive - 3" odd.
    This is a pd130 engine though, and a different car.
    Jason - Rather mad Skoda Fabia driver.... Odd whiff of diesel coming from him.
    260bhp Skoda Fabia TDI Dyno Run
    http://www.youtube.com/watch?v=9BvjJjL7Z50
    315bhp Skoda Fabia TDI Dyno Run (2013)
    http://www.youtube.com/watch?v=TOE4nbT5NGY
    Feb 2007
    Leicester
    Yes, it does look about 72mm diameter.
    Can anyone tell me whether it is possible to replace the oil filter on a 2001 115hp PD engine without replacing the oil? I changed the incorrect 10W 40 oil put in by my local garage for 5W 40 PMillers XFE-PD oil. However, i didn't have the right tool to remove the air filter so i had to leave that in place. I am not convinced the garage changed the filter (don't worry, i no longer use them) so i would like to swap it anyway. I am concerned that the oil will come out of the top of it? Can anyone advise?
    Oct 2005
    Lutterworth
    Quote Originally Posted by wid77 View Post
    All the oil will be in the sump if you have not started the engine.....
    An easy swop out
    Passat 1.8SE 1998
    Oct 2005
    Lutterworth
    Quote Originally Posted by devonutopia View Post
    I guess a 32mm will do as long as it is a six-point.
    My 12-point looks like it would round-off the corners so I went for the large socket that fits canister style filters as well.
    Passat 1.8SE 1998
    Feb 2007
    Leicester
    Quote Originally Posted by Lex Luthor View Post
    An easy swop out
    The engine has been started as i use the car daily. Are you suggesting that the oil will come out the top of the filter housing when i take the plastic cap off? Sorry to sound stupid on this one. I assumed the oil would drain down to the sump if left for a few minutes and then i could whip out the filter and change.
  1. S4 air filter
    By Ftagi in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-05-2007, 12:22 PM
  2. Sumkind of engine air filter??????????
    By KIDDAJOJO in forum Archive posts
    Last Post: 07-05-2007, 11:40 AM
  3. Oil in Air filter.
    By colifeashots in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-04-2007, 05:46 PM
  4. Where is oil filter - Audi A4 115 PD engine?
    By wid77 in forum Archive posts
    Last Post: 24-02-2007, 08:51 PM
  5. Oil Filter For 2002 A4 1.8T Engine Code AVJ
    By Gazz in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 11-01-2007, 12:22 PM
