Thread: Gearbox Winding
Results 1 to 9 of 9
  1. Gearbox Winding
    nottinghamshire
    Hi Quick Question, When Im Driving And I Let Off The Throttle And Im Rolling In Gear, The Gearbox Seems To Wind Slighlty, The Slight Noise Stops When I Dip The Clutch Or I Accelerate Again.
    Would This Be A Sign Of The Gearbox Oil Needing A Top-up?
    Thanks In Advance
  2. Re: Gearbox Winding
    Mine is doing this too - I hope it just needs a top up/change. Hopefully someone will be along shortly with an answer
  3. Re: Gearbox Winding
    nottinghamshire
    Anyone??????
  4. Re: Gearbox Winding
    nottinghamshire
    bump.............
  5. Re: Gearbox Winding
    Jan 2009
    so is mine especially in 1st gear .sorry i know this is no help but couldnt not have a look when i saw the post
  6. Re: Gearbox Winding
    Canada
    Quote Originally Posted by dirtyderv View Post
    If your on about the gearbox oil, they are considered sealed for life, so no need to top up unless you have a leak.
    as for the OP could we have year and specific model of car, the whine maybe thrust bearing, but that usually when the clutch is dipped ie the bearing is under load.
  7. Re: Gearbox Winding
    Mine is a late 02 TDI 130, 6 speed box. Whine only audible when you let off the accelerator in gear. Al.
  8. Re: Gearbox Winding
    Jun 2008
    same happened to mine. needed a new gearbox. 3rd gear used to shunt itself out back into neutral but after about a month of driving with that sound.
  9. Re: Gearbox Winding
    Feb 2009
    South Yorkshire
    Hi All, I'm new to the forum . I've had my Passat for 3 years now and it has been whine-ing for the last 6 months, you can hear it above 40MPH and the pitch changes with road speed rather than engine speed, I've been told its the differential bearings. Going to cost arm and leg as clutch on its way out too. Going to get it done at local VW specialist. I'll let you know how it goes after the 16th of Feb, when it goes in.
  1. Alhambra spare wheel winding mechanism
    By Robin Vitiello in forum Alhambra
    Last Post: 02-05-2009, 09:29 PM
  2. Gearbox DFH, will it fit replace my gearbox DFK?
    By red_avant in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-10-2008, 05:32 PM
  3. 1999 Cabriolet seat belts not winding
    By Walesgbn in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 22-02-2008, 01:58 AM
  4. Winding noise,cutting up inside of front tyres??
    By 80quattro1987 in forum 80 - 90
    Last Post: 19-01-2008, 02:30 PM
  5. Best gearbox oil
    By vincentbob in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-06-2007, 12:09 PM
