Hi all,ive got a Gti 1.8t and the sump is cracked which led to all the oil being let out of the sump. the engine code is an AGU, i want to repair this properly so naturally its a new sump,gasket and bolts.does it matter which sump i use or can i use any sump that came off a 1.8t thats used in a fron wheel drive? ie could i use a AUQ,BAM etc engine sump?thanks for help!
