Thread: 3.0tdi cutting out
Results 1 to 8 of 8
  1. 3.0tdi cutting out
    May 2008
    Hi All
    I have a 3.0tdi quattro avant with a manual gearbox and a few weeks ago all of sudden on the motorway the yellow coil light on the dash starts flashing and the car wont go over 2500 revs. i have to restart the car for the light to go off but as soon as i put my foot down a little the light starts flashing again and i'v lost power. this is happening all the time now and i'v been to a garage for diagnostics, it came up with a fuel pressure fault (sounds expensive).
    any one had this problem before?
    any advice would help.
  2. Re: 3.0tdi cutting out
    134 Post(s)
    2022 Post(s)
    What was the fault code number?
  3. Re: 3.0tdi cutting out
    May 2008
    sorry i wasnt given the fault code number
  4. Re: 3.0tdi cutting out
    Huddersfield, West Yorkshire.
    It could be expensive but you own an Audi A4 3.0TDI, you should expect to pay the right money for such a car.
  5. Re: 3.0tdi cutting out
    134 Post(s)
    2022 Post(s)
    Typical, why is it that garages don’t give people the fault code report they have paid for? I give people a full print out and keep the scan on the server permanently, I have ever scan I have ever done. Without a fault code number I am stuck to help you. The most likely possibility is that the high pressure pump is faulty and yes, they are very expensive at £1100 plus fitting. What is the engine type code, BKN or ASB?
  6. Re: 3.0tdi cutting out
    May 2008
    i can get the fault code tomorrow,
    and the engine code is BKN
  7. Re: 3.0tdi cutting out
    May 2007
    knee deep in clunge
    14 Post(s)
    this is common its possibly high pressure fuel sender (Quick test of the measured values will give you actual rail pressure and disconnecting the sender will restore default pressures and return the power)or the turbo electric wastegate motor reading implausible signal (over boost which in turn will reduce fuel pressure to protect the engine)the motor can be replaced separate from the turbo and its dealer only as this has to be calibrated but as crasher says the fault code will shed more light on the matter and also ambient readings will give the tech more live feedback like actual boost and rail pressure plus rpm and frequency of fault.
  8. Re: 3.0tdi cutting out
    May 2008
    thanks for the help tonight fellas
    i will get all the data tomorrow and post as soon as i can,
  1. Looking at a 2.0TDi DSG...
    By Mooseyboy in forum Audi A3 - Archive Topics
    Last Post: 18-11-2008, 11:54 PM
  2. Question A4 2.0T or 2.0TDi?
    By Combover in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-07-2008, 04:03 PM
  3. Got my A4 B8 2.0Tdi SE
    By smac1968 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 25-03-2008, 02:39 PM
  4. What to buy A6 2.0TDI or A6 2.7TDI or A4 2.0TDI
    By sanstorm999 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 28-08-2007, 01:07 PM
  5. A4 2.0TDI 170 PSI SE Re Map
    By marcus in forum Audi A4 - Archive Topics
    Last Post: 03-08-2007, 02:30 PM
