Thread: Le Mans Tyre pressures
  1. Le Mans Tyre pressures
    Jul 2015
    Ipswich, Suffolk
    Hi everyone,
    Recently bought a 2008 A6 Avant Le Mans 3.0TDI Tiptronic from an independant dealer.
    The ride on the drive home was firm but not overly so.
    I checked the tyre pressures the next morning and they were 26psi all round!!!
    I pumped them up to 44psi front and 38psi rear, then drove it.
    If I were to run over a penny I could tell if it was heads or tails the ride is so hard.
    The tyres are 235/35/19 Continentals with about 5mm of tread left, evenly worn.
    Do you all run at these pressures or is there a reduced pressure you can run at without compromising tyre life?
    Pat
    "Too much power is just enough." Carrol Shelby.
  2. Re: Le Mans Tyre pressures
    Oct 2005
    The recommended tyre pressures should be on the inside of the fuel filler flap or in the manual.
    Edit: Double check that tyre size too, OE size for 19s is, IIRC, 255/35/19
  3. Re: Le Mans Tyre pressures
    Nov 2012
    Somerset UK
    ^+1
    If you're car doesn't have the sticker you can order a replacement from your Audi main dealer, these will differ from car to car (I think they are about £4).
    It is common practice for 3rd party garages to reduce pressures in tyres of cars that are known for their hard rides.
    Before buying my SE in 2012 I did several internet searches on the various models and knew that the S-line/LeMans were noted for their harder ride, I test drove one (main dealer) and then decided to go for the SE
  4. Re: Le Mans Tyre pressures
    Jul 2015
    Ipswich, Suffolk
    Apologies the tyres are 255/35/19. Thank you for your wisdom.
    44 front and 38 rear are what is advised inside the fuel filler flap.
    I expect I will get used to it, but the bill to replace all my fillings
    is going to be enormous.
    Pat
  5. Re: Le Mans Tyre pressures
    Jul 2015
    Ipswich, Suffolk
    Thank you Rhory, I will try 40psi all round.
  6. Re: Le Mans Tyre pressures
    Jul 2015
    Ipswich, Suffolk
    Hey Rhory thanks for the heads up that is a bargain.
  7. Re: Le Mans Tyre pressures
    Aug 2015
    The ride is 'firm' isn't it.
    I'm planning on getting some winter tyres, so I'll probably buy a 17" wheel/tyre package from mytyres.co.uk - I can get a set of 17" wheels and tyres for the same price as 19" tyres only. Then in the spring I'll probably buy another set of wheels & tyres.
  1. Tyre Pressures
    By swampey in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 07-10-2011, 09:09 AM
  2. Le mans tyre pressures
    By haysy in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 27-03-2011, 06:52 PM
  3. Tyre pressures & Tyre wear?
    By derekm in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 28-03-2010, 09:22 PM
  4. Tyre pressures and tyre pressure warning light
    By Foxtrot Oscar in forum Golf MK6 - 2009 - 2013
    Last Post: 26-07-2009, 07:14 PM
  5. t5 tyre pressures ???
    By paul600rr in forum The Commercial Range
    Last Post: 22-06-2007, 04:48 PM
