Thread: Fast idle + engine management lights on
  1. Fast idle + engine management lights on
    Hi, My first post - been lurking a while and learning lots.
    Got a problem with my 2003 1.8t Quattro and would be interested in people's opinions. Yesterday while driving home I felt a slight hesitation while at speed but nothing else happened and car carried on. On stopping at some traffic lights I noticed the idle speed was 1200 rather than the usual 800 or so. Revved it but no change so stupidly turned the engine off to see if that reset it. Engine really struggled to start (as if flooded) and when I finally got it going the EPC warning was on in the dash and it was still idling at 1200. Tried this again when I got home and the same thing happened and in addition the other engine management light came on. Tried again this morning with a cold engine and it starts first time with the idle easing back to 800 as normal. The EPC light was off but the other engine management light is now permanently lit.
    I'm guessing this is a temperature sensor issue but a little confused as to why the idle has gone back to 800 this morning - if the sensor is broken then why is it not staying at 1200? Does anyone have any other ideas?
  2. Re: Fast idle + engine management lights on
    Southern County Softy
    20 Post(s)
    Get a fault code scan.
    It could be a sticky throttle body.
    A4 2.5 tdi QS (mapped)
  3. Re: Fast idle + engine management lights on
    Dec 2006
    or it could be a leaking vacum hose, which is over rev'ing it to make sure it does not stall...
    Rick
  4. Re: Fast idle + engine management lights on
    Thanks for the suggestions - the fault code indicates it's the engine speed sensor. It's being replaced today so hopefully that will be an end to it.
  1. Fast idle speed
    By dagorian in forum Golf MK2 - 1984 - 1992
    Last Post: 18-08-2008, 10:25 PM
  2. Engine management and ABS lights
    By Panzerdriver in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-07-2008, 04:01 PM
  3. Fast Idle
    By martlinel in forum Golf MK3 - 1993 - 1999
    Last Post: 14-02-2008, 10:05 PM
  4. fast idle
    By liambell in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 14-08-2007, 12:16 PM
  5. 02 Golf TDi Engine Management Warning and Brake Lights
    By nhi336 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 20-04-2007, 10:29 AM
