Thread: Injector Cleaner
Results 1 to 10 of 18
  1. Injector Cleaner
    Hello,
    Can anyone recomend an Injector Cleaner?
    Many Thanks
    G
  2. Re: Injector Cleaner
    Jul 2008
    Bristol
    Quote Originally Posted by ggmoney99 View Post
    Hello,
    Many Thanks
    G
    1) Redex injector cleaner
    2) STP
    3) Slick 50
    I would go for Slick 50 not only cleans the fuel system but also helps combustion chambers and intake valves. It is on the expensive side, i think £14.99 400ml.
  3. Re: Injector Cleaner
    Mar 2007
    Lancashire
    There's also Forte which is highly used and recommended.
    A4 1.9TDI 160bhp Sport - 2001 (51)
    Re-map by more-bhp.
    TT 3.2 V6 DSG quattro 270BHP - 2003 (53)
  4. Re: Injector Cleaner
    Are these all fuel additives?
    I once used a spray, about 7 years ago, that sprayed directectly into the intlet manifold.
    It gave great results, but I can't remeber what it was called.
    How often do you use the additives?
    Does anyone know of a good spray?
  5. Re: Injector Cleaner
    Sep 2008
    London
    Quote Originally Posted by Zeb View Post
    2) STP
    3) Slick 50
    how do these work? do you pour it in with the fuel? never used one before but would like to treat the engine to a nice clean instead of the external all the time
    Audi A4 2004 1.8T S-line (190) Multitronic Misano Red
    _______________________________
    Retrofitted: cruise control/(Hazzydays)
  6. Re: Injector Cleaner
    I've remembered the name of the product I used and had good results with:
    10K Boost. Has anyone used this?
  7. Re: Injector Cleaner
    Nov 2008
    Quote Originally Posted by Mr_Meeks View Post
    Yes I believe all of those are ones which you add to say 50 litres of fuel.
    I use the STP fuel system cleaner which is £15 from Halfords.
    Did a bit of research a and that seemed to be the best that was available over here apparently, it would seem you get what you pay for with these additives.
    An even better one was called BG44K but I could not find anyone near me that sells it!
    An ideal time to use some would be before an oil change as some of the additives can work their way into the oil
  8. Re: Injector Cleaner
    Nov 2008
    Oh and no I don't work for Halfords
  9. Re: Injector Cleaner
    I've found it here:
    http://www.powerenhancer.co.uk/produ...4k--for-petrol-
    Looks interesting. Bit easier to apply than the 10k Boost
  10. Re: Injector Cleaner
    Mar 2007
    Lancashire
    I've read mixed views with these. Forte do one that cleans the piston crown, injectors and ensures a good spray patter, better burn and therefore less unburnt fuel to carbon up the EGR and turbo.
    I use Millers DSP 4 at the moment, not every tank. I tend to use an additive more so in winter.
    I'm sure BG44K is an ingrediant with the additive that is supposed to be good!! I'll have to do some more research. The octane rating is not raised with Forte, but with the others it's typicaly by 3-5.
    Re-map by more-bhp.
  1. Diesel Injector Cleaner - How often to use?
    By Perry in forum Chat - Anything with wheels
    Last Post: 13-12-2010, 08:34 PM
  2. Question Air cleaner removal
    By mikefase in forum Golf MK4 - 1999 - 2004
    Last Post: 07-09-2008, 12:23 PM
  3. Diesel injector cleaner
    By tyberwan in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-09-2008, 12:08 PM
  4. Fuel Filter + injector cleaner
    By arl_gti in forum Golf MK4 - 1999 - 2004
    Last Post: 24-04-2008, 05:49 PM
  5. Injector cleaner Worth it ?
    By TheMadhatter in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-12-2007, 10:05 AM
