Thread: engine issue- 2 of them!
Results 1 to 10 of 15
  1. engine issue- 2 of them!
    Dec 2008
    Oxfordshire
    I have an A4 Cabriolet 1.8T 54 plate on 52K miles. I currently have 2 issues that I need help with...anyone out there!?
    1. I had a warning symbol flash-up 10 days ago stating oil pressure. I slowed down (as I was going fast) the warning light went off and has never returned!
    2. Recently I have had a problem with engine noise on start up, unlike before when start-up was pretty quiet. After 30 seconds the noise passes and tone is reduced. I have a friend who's said it's due to cold weather, but I bought this can in Jan 08 and it was quiet then.
    Are these problems linked, as they've started around the same time?
    Whoever answers this....thanks in advance.
    Kenny
  2. Re: engine issue- 2 of them!
    Sep 2008
    Birmingham
    Quote Originally Posted by kennynj View Post
    Kenny
    Is it a knocking on startup? They could be related, it might be worth taking it to a garage to check. If there is an oil pressure issue it could cost a lot to put right if left.
  3. Re: engine issue- 2 of them!
    Aug 2008
    poole,dorset
    if youve got low oil pressure it might mean that after its left for a while all the oil drains in to the sump and when you start it up its taking a while to get the oil back up to the head so that would make more of a noise and do damage, best to get to a garage asap!!hope this helps
  4. Re: engine issue- 2 of them!
    1837 Post(s)
    Stop driving the car, the oil pump pick up gauze in the sump is blocked. If you continue driving it, the engine and turbo will fail, this is an extremely common problem on the 1.8T engine, especially those in the longitudinal install position such as the A4, A6 and Passat. The sump will have to come off which means dropping the subframe down.
  5. Re: engine issue- 2 of them!
    Sep 2008
    Birmingham
    Doing my usual flick through I didn't even notice it was a 1.8T, not good.
    If it's developed a knock the bottom end may have been damaged already.
  6. Re: engine issue- 2 of them!
    Dec 2008
    Oxfordshire
    Thanks for your replies....however getting a little nervy about the issue...no money, credit crunch etc.
    You all answered about a knocking sound, there's no knocking, if so very faint, its more of a wineing sound for 10 seconds. Someone said it's the pump kicking in and is noisier in winter.
    I have to say though, i have to wait a few moments for the car to warm up, as it seems very sluggish if I set straight off...again this is a new thing just happened.
    Also, it doesn't happen when warm, so if I took it to a garage now, it's very difficult to spot the issue
    Do I have to take it to a Audi dealer, or could anyone sort it? If it is as bad as you're all saying, what cost do you think I'm looking at?!
    Thanks guys
  7. Re: engine issue- 2 of them!
    1837 Post(s)
    Any decent garage can drop the subframe and then the sump. At the very least you should have an engine flush and oil change as this sometimes holds back the problem for a while BUT flushing can actually cause more debris to become detached from the internals of the engine and so make the problem worse. If you leave it, it WILL write off the engine and the turbo and that is at least £1K of work even using second hand parts at the cheapest garage you can find. To fix it properly using all new genuine parts can cost in excess of £6K. The supply of second hand 1.8T engines is very limited, it is a rare car compared to other models and the demand is huge as this is such a common problem.
    This thing about the credit crunch and you having no money, I hear this a lot. Why have the current problems affected your financial position? Have you lost your job? Did you have any more money this time last year?
  8. Re: engine issue- 2 of them!
    Dec 2007
    Thanks guys
    oil pump pick up pipe geting blocked only thing it will do is get worse and take the turbo an engine with it im lucky and know loads of mech.s wen mine went full head was replaced turbo lucky the bottom end was ok just over 2k for me but if you dont know blokes in the trade ur lookin 3k ish and the 18T engine is near imposible to get second hand
  9. Re: engine issue- 2 of them!
    Sep 2008
    London
    Thanks guys
    i started my car the other day and heard a whining sound towards driver side of the engine i didn't think nothing of it as it went after 10-15 sec or so and it was a very cold day + i dont commute to work with my car so most of the time its just parked looking pretty but now im a lil bit worried from what you guys are saying in this article.
    Audi A4 2004 1.8T S-line (190) Multitronic Misano Red
    _______________________________
    Retrofitted: cruise control/(Hazzydays)
  10. Re: engine issue- 2 of them!
    1837 Post(s)
    Only worry if the oil light comes on.
  1. 05 2.0tdi Idle issue & '97 1.8 engine issue
    By dbbear in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 18-08-2009, 02:11 PM
  2. Injection Start Control - boost issue on AHU tdi engine
    By simyboye in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-03-2008, 07:40 PM
  3. Mk3 1.4 Engine/Clutch Issue
    By Mattster in forum Golf MK3 - 1993 - 1999
    Last Post: 29-12-2007, 09:39 PM
  4. Help with possible MAF issue
    By ali_da_badass in forum Golf MK4 - 1999 - 2004
    Last Post: 26-11-2007, 10:28 PM
  5. `94 1.8 Driver - Fault code/issue ABS engine
    By BugsyMalone666 in forum Golf MK3 - 1993 - 1999
    Last Post: 22-11-2007, 05:18 AM
