Thread: GearBox Oil Level
  1. GearBox Oil Level
    Aug 2006
    Before checking the oil level on my 130TDi (5 Speed) I thought that I'd read the instructions in ElsaWin.
    It first of all states that the oil "Specified value: oil level 7 mm below bottom edge of oil filler hole."
    but then goes on to say
    Note:
    The oil can be filled up to the bottom lip of the oil filler hole when servicing.
    Is there something lost in translation or is it the Celtic interpretation of the language; they can't both be right.
    Oct 2006
    Sounds a bit daft, how would you know its 7mm from the hole!?!?!? Unless you dip your finger in and measure it.
    Normally it's level with the bottom of the filler hole, or fill it until it starts to come out. On a flat surface you can leave it until it stops dripping out. Difficult I know to do unless you have a garage car lift. At home its case of it not being straight on a jack. Suppose you could fill it, lower the car back down so the car is level, raise back up and stick the plug back.
    Just changed the gearbox and diff oil on the Z3. The manual says its a non drain and filled for life, but the diff oil was a tad manky!!
    Oct 2005
    Lutterworth
    Quote Originally Posted by Celtic Cousin View Post
    Note:
    Seems quite straight forward...
    The factory fill leaves the oil level 7mm below the hole, but for servicing purposes you are allowed to fill it to level....
    Passat Estate 2002 PD130
    Passat 1.8SE 1998
    Aug 2006
    Of course filling to the level stud appears logical but in ElsaWin it's always refered to "Oil Filler Stud"
    What also seemed strange is that they recommend that "..........check oil level with locally manufactured tool e.g. a piece of angled wire".
    I only wanted to check the level because the gearchange is tight between 1st & 2nd (even when hot), or does anyone have an alternative suggestion for a cause for this. Car has travelled 51k
    Apr 2005
    Bristol
    most in the trade will top up via the filler hole until it runs out (if using a pump system)
  6. Re: GearBox Oil Level
    Sep 2007
    can anyone tell me where the filler plug is? I have a 96 a4 tdi with the 1z engine, the splined drain plug is easy enough to find, struggling with where to refill it from though!
  7. Re: GearBox Oil Level
    Aug 2006
    On a 2002 (5 spd) version the filler is through the plug which is located on the box casing by the LH driveshaft output.
    I added some STP gearbox treatment which made the change much sweeter.
  1. Minimum Oil Level Light
    By Mike Brown in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 05-01-2008, 07:01 PM
  2. Passat - Oil level warning light.
    By Brian Rouse in forum Archive posts
    Last Post: 22-09-2007, 01:56 PM
  3. mkv golf coolant level
    By Paul_mkV_golf in forum Golf MK5 - 2004 - 2009
    Last Post: 20-12-2006, 02:18 PM
  4. Oil Level and yellow oil light
    By Trucypriot in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 22-10-2006, 01:53 PM
  5. Coolant level
    By djsoftware in forum Passat - Archive Topics
    Last Post: 08-08-2006, 01:13 PM
