Thread: Greasing wheel bearings - Copper grease?
  1. Greasing wheel bearings - Copper grease?
    Is it ok to grease wheel bearings with copper grease? I fitted new rear hubs + bearings to my passat a month or two ago, have not used it much since. Found a sachet of Wheel bearing grease today - it seems to be much thicker gooier stuff than the copper grease. Should I be whipping the hubs off and bunging a load of this stuff in?
    (1994 passat L 2.0 petrol 8valve)
    -Derek
  2. Re: Greasing wheel bearings - Copper grease?
    Pembrokeshire
    22 Post(s)
    i dont know what affect copper grease will have on wheel bearings, as i have never tried it. copper grease is an anti seize agent used to prevent corossion, and doesnt really have the lubricating properties of thicker wheel bearing grease. I think your best move would be to thoroughly clean your new bearings using a degreaser, to remove every trace of copper grease, then liberally apply the correct grease, making sure you thoroughly work it into the wheel bearing.
  3. Re: Greasing wheel bearings - Copper grease?
    134 Post(s)
    2025 Post(s)
    No, copper grease is not suitable for wheel bearings, it has the completely wrong characteristics, in fact it could build up on the rollers due to pressure welding of the copper and cause failure of the bearing due to overheating.
    Take care when replacing a rear wheel bearing, mistakes can kill!
    http://www.mailonsunday.co.uk/news/a...s-tightly.html
  4. Re: Greasing wheel bearings - Copper grease?
    Cheers guys
    That'll teach me for using the nearest thing.
    Oh well, at least its easily rectified.
  1. Audi 80 wheel bearings
    By diamondbrit73 in forum 80 - 90
    Last Post: 23-02-2010, 12:02 AM
  2. wheel bearings
    By smep in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-12-2008, 12:31 AM
  3. Please Help Changing wheel bearings
    By njm in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 16-07-2008, 09:52 PM
  4. Wheel bearings
    By waynetdi130 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-07-2008, 03:12 PM
  5. A4 Wheel Bearings
    By audiminor in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 04-03-2008, 08:53 PM
