Thread: A6 Electric window prob
Page 1 of 3 123 LastLast
Results 1 to 10 of 30
  1. A6 Electric window prob
    otter Guest
    Hi, I am the proud new owner of an Audi A6. It a superb car to drive with silky smoth ride and auto transmission. However, I have a problem with the passenger side elec window. It seems the motor is fine but the window seems very stiff and as it nears the top of its travel it gets too much and stops. I have tried spraying silicone spray in to the mechanism as the window goes down, this has helped a bit but it still will not close without one hand each side helping it up. Could anybody give me any useful tips or the best way to remove the door trim without damage so I can take a look at the mechanism itself?
    Many thanks Steve
  2. Further A6 window problems
    Jun 2006
    I have exaactly the same symltoms on my 1999 A^- again on the passenger side. Any ideas?
  3. Re: A6 Electric window prob
    Jun 2006
    In the end I used the silicon spray on the window channel which cured the problem and it has worked for the last 2 years.
  4. Re: A6 Electric window prob
    Dec 2007
    Had that prob meself and the cure was the motors where tired and replaced got them off e-bay could buy off audi by £150 each?
    to remove door panel 2 screws at top of trim at the edge of the door once done just lift the door handle up and the whole panel will come up
    have fun
  5. Re: A6 Electric window prob
    May 2007
    Hi Guys,I had the same fault with my rear driver's side window it needed to be pulled up with 2 hands to close fully but silicone spray in the channels seems to have cured it for now.However my driver's door window makes an unpleasant squeaking noise inside the door as it goes up and down,the noise is very bad in warm weather but disappears completely in cold weather,any ideas?Regards Ken.
  6. Re: A6 Electric window prob
    Dunedin, New Zealand
    If the silicon spray doesn't work, try a new window regulator. The motor is generally OK, it's the regulator (the bit that hold the window and moves it up an down when powered by the motor) that can sieze up. Price isn't too bad.
  7. Re: A6 Electric window prob
    May 2007
    Thanks Kiwi,will investigate that if taking off the door panel is as easy as Audiqs says.Ken.
  8. Re: A6 Electric window prob
    Mar 2008
    Had my rear window guides greased by my local (non Audi) garage two years ago and everything still fine. Window would stop closing about half way up. Worth a go before replacing the motor.
  9. Re: A6 Electric window prob
    Aug 2008
    My A6 displayed all the symptoms, went down no problem but as it got half to three quarters up, it sent itself back down again. The only way was to help it up to close it properly.
    It turned out to be the pink clips which audi upgraded from blue ones as the plastic wasn't strong enough. These clips attach the glass to the window cables that lift it up, what happen is the top of the clip breaks.
    The good news is it's all documented here, a thread started by wainwriv 22-08-09 tells you all about it and is where i got my info.
  10. Smile Re: A6 Electric window prob
    Oct 2010
    pitesti
    My A6 has same problem with left passager window and i”ll be glad to find from you a good and cheap solution
  1. Electric Window Fault
    By beltaine in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 29-10-2007, 02:08 PM
  2. Electric Window
    By LLX in forum Polo - Derby - Lupo - Fox
    Last Post: 20-04-2007, 11:49 PM
  3. electric window
    By sumanb82 in forum Audi A3 - Archive Topics
    Last Post: 14-04-2007, 08:56 AM
  4. electric window problems
    By nobby.arny in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 30-01-2007, 08:12 AM
  5. Audi Convertible - 1994 - Elec Window Prob!
    By Will Giles in forum Archive posts
    Last Post: 30-10-2006, 05:14 PM
