Thread: A3 excessive disc wear
Results 1 to 9 of 9
  1. Angry A3 excessive disc wear
    Feb 2007
    My 1st A3, 03 reg, 1.8 had the front discs and pads replaced three times in 3 years that I owned it. My annual mileage was 10-12k pa. This was not accepted under warranty and it turned pretty expensive.
    my 2nd A3 1.8 06 reg just over one year and done 12k will now require new discs and pads. I don't believe how unlucky I feel. Is this right?? i'm an average driver, I don't race or brake hard. Anybody else had this problem? Fazer.
    Yorkshire
    Our A3 Tdi has done 30k without any new discs on the front and one set on the rear.
    Dec 2006
    Wiltshire
    I did over 50K in my old S3 including some fairly hard motoway/autobahn stuff and never had the discs changed.
    Have done 54K in the A4 and still on original disks as well.
    You don't leave the car unused for long periods? If they are being replaced for wearing out it sounds a bit odd, you or another driver drive with a foot hovering on the brakes. (not wishing to state the obvious or insult anyone)
    If they are warped then I would have thought it was a warranty issue?
    A6 (2007)TDi SE Avant
    Gone but not forgotten - A4 2.5TDi Avant, Imola Yellow S3 , Golf VR6 Highline
    Feb 2007
    Quote Originally Posted by Froggy View Post
    Hiya Froggy, the car is used everyday... dozen miles to work then back... drive to dundee and lake district several times but thats motorway driving... the driving is regular, no foot hovering on brake... its weird, the service technician at Audi is adamant that the discs and and pads can last anywhere from 8 to 40k ... so tis not warranty work. They dont bind and the calipers arent seized. This'll be my last Audi I gave it a second chance...
    Fazer.
    Yorkshire
    Have you seen the worn out discs that have been removed from your cars?
    Feb 2007
    No... but this weekend I'm stripping em down... discs and pads and checking out everything myself and taking precise measurements of the disc thickness... audi tell me that 22mm is min thickness.. also will try and check for DVT but I dont think this is a factor as there is no pulse or anything feed back thru the pedal..
    Dec 2006
    NE Fife
    Our A3 (130 Tdi) covered 60k miles before it required any discs / pads to be changed.
    Were the replacement parts genuine Audi ?
    One factor could be cleaning the car with a power washer and then leaving it for a period of ime (say, overnight) before driving it. This allows the discs to be covered in a film of water - discs can go rusty very quickly due to this. This would especially tbe he case with an 'open' wheel design.
    The rust cleans off quickly in use but I should imagine that it would cause the need for premature replacement.
    Just a possibility ?
    Hope that this helps,
    Bob
    Feb 2007
    My 1.8t is only on its second set of discs at 88k, do them yourself avoid kwikfit ! ha
  9. Re: A3 excessive disc wear
    Aug 2007
    Hi Frazer
    I have a Golf Mk5 and my discs require replacing at 15,000 and I am, likewise, racked off because they are not covered by warranty.
    Steven-John
  1. Excessive front tyre wear
    By ColinT in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-05-2007, 12:32 PM
  2. Excessive Brake Travel
    By jay77 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 22-04-2007, 10:20 PM
  3. VR5 excessive oil usage
    By seemiles in forum Passat - Archive Topics
    Last Post: 27-03-2007, 12:46 PM
  4. whats going on excessive diesel usage!
    By vw754 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 07-02-2007, 04:11 PM
  5. Excessive HC content in emissions.
    By H. Macari in forum 80 - 90
    Last Post: 16-02-2006, 06:39 PM
