Thread: How to get rid of yellow warnings (windscreen washer level etc)
Results 1 to 10 of 13
  1. How to get rid of yellow warnings (windscreen washer level etc)
    Aug 2007
    Newport, Wales
    7 Post(s)
    I love my B7 A4 but I get really annoyed when the yellow washer level low warning appears at the beginning of a 3 hour journey and I have to look at it flashing away for the whole journey! Is there any way to "dismiss" it?
    I have managed to hide it temporarily by activating the phonebook menu on the Driver Information System (between the speed & rev counter) but this means I can't change tracks on my CD player because the scroll button (on the steering wheel) just scrolls through phonebook names instead of changing the CD track!
    On the couple of Mk.4 Golfs I owned, if a yellow warning popped-up (washer level low, Fuel low etc) you would get rid of them by pressing a button on the MFA stalk (trip computer thingummy)!
    Any advice appreciated!
    Al.
    [ My Cars: 2011 Caravelle SE TDI LWB | 2015 A1 1.4 TFSI | 2017 Jag F-Type R 5.0 V8 Supercharged ]
    [ Past Audis:
    A6 S-Line 3.0
    V6 TDI Qttr | A4 3.0 TDI Qttr S-Line | S6 4.2 Qttr | A4 2.5 V6 TDI Qttr Sport | A4 1.9 TDI Qttr S-Line | A4 SE 2.0 TFSI Quattro Avant | 2.0 TFSI Roadster ]
    [ Past VWs: Mk1 GTI Cab | Mk3 2.0 Cab |
    Mk3 VR6 | Mk4 R32 | Mk4 V6 MoFo | Mk4 Golf 1.9 TDI| Mk4 Supercharged 2.0 6-speed | VW Touran 2.0 TDI DSG ]
  2. Re: How to get rid of yellow warnings (windscreen washer level etc)
    Aug 2007
    Newport, Wales
    7 Post(s)
    PS: Yes I know.. fill up the washer fluid tank is the answer...
    But when the warning lamp comes on, there is still plenty of water left and if it's a perfectly dry day.. I don't feel inclined to stop for water just to stop the warning light from coming on!! [Rant over]
    [ Past Audis:
    A6 S-Line 3.0
  3. Re: How to get rid of yellow warnings (windscreen washer level etc)
    Jun 2008
    Marmitehampton
    Hey Toff,
    I don't think there is a way of dismissing it, however I was recently reminded of just how useful the washer bottle warning is... I had a new Focus hire car which ran out of washer fluid without any warning whilst on the M1. 6 miles (felt like 60) with the winter sun shining on a filthy windscreen was not a very pleasant experience...
    If it goes off, fill it up! I know that isn't what you wanted, sorry!
    fM
    2007 Audi A4 2.0 TDI 140PS | S-Line | BOSE | Volterra Leather
    Retrofitted | RNS-E | SDS | Bluetooth | Cruise Control | Parking Sensors | Arm Rest | DIS
  4. Re: How to get rid of yellow warnings (windscreen washer level etc)
    Norwich
    Yep strange one this- when I had my 2005 B7 it had the monochrome DIS and the screenwash level warning would flash up for two minutes and then go off for around 30mins before coming on again and so on.
    My new one has the colour DIS and the warning stays on permanently which is a bit annoying.
  5. Re: How to get rid of yellow warnings (windscreen washer level etc)
    Jun 2008
    Marmitehampton
    Monochrome DIS has same behaviour. I wonder if it could be altered in VAG-COM?
  6. Re: How to get rid of yellow warnings (windscreen washer level etc)
    Jul 2008
    northern ireland
    if it is a 2 wire sensor going to the water bottle cut the 2 wires twist them together and stick them in a block connector.
  7. Re: How to get rid of yellow warnings (windscreen washer level etc)
    Aug 2007
    Newport, Wales
    7 Post(s)
    Quote Originally Posted by spacedoutracer View Post
    ...or wire in a 555 timer to do the same job, but re-instate the sensor every hour!
    ...or carry a small bottle of water in the boot, so you can top-up the water level just enough stop the warning coming on!
    There are a few work-arounds but it'd be great if there was a software (VAG-COM) solution.
    Damn the person / team at Audi who decided to make the warning permanent!
    [ Past Audis:
    A6 S-Line 3.0
  8. Re: How to get rid of yellow warnings (windscreen washer level etc)
    Jun 2008
    Marmitehampton
    Easiest thing would be to remove the instrument cluster, tap in to Pin 1 of the blue plug with a Scotchblock and earth it. This will permanently disable the washer bottle sensor.
  9. Re: How to get rid of yellow warnings (windscreen washer level etc)
    Aug 2007
    Newport, Wales
    7 Post(s)
    But in the process, I might accidentally permanently disable my car!
    Does pin 1 on that connector just have one specific purpose?
    [ Past Audis:
    A6 S-Line 3.0
  10. Re: How to get rid of yellow warnings (windscreen washer level etc)
    Angus, Scotland
    Hi Toff,
    Yeah, pin 1 is purely for the washer level sender. If you follow pin1 it goes down to one pin on the sensor and the other pin then goes back and is cnnected to earth so as the water level is above the top pin on the sensor the circuit to earth is made and once the water goes below the top pin the circuit is broken and the warning pops up!!
    This is why when you retro-fit DIS you have to either install the washer level sensor or just ground pin 1.
    Hope that clears it up a bit
    Paul
    A4 B7 S-Line 140 TDi
    Phantom Black, Bose Sound System, Arm-Rest, Retro-Fit DIS, Retro-Fit Cruise
    Fully registered Vag-Com/VCDS Hex-CAN
  1. Question Windscreen Washer Pipe
    By John S in forum Jetta MK3 - 2005 - 2013
    Last Post: 29-04-2009, 03:25 PM
  2. Question Rear windscreen washer
    By cornishboy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-07-2008, 08:57 PM
  3. Windscreen washer nozzles
    By broket in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 15-05-2008, 08:38 AM
  4. Washer water level indicator light
    By Fettler in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 12-01-2008, 09:07 PM
  5. Oil Level and yellow oil light
    By Trucypriot in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 22-10-2006, 01:53 PM
