Thread: Audi Cab Boot Won't Open
  1. Post Audi Cab Boot Won't Open
    robnicolaou Guest
    Help!!! i've a 1998 Cab and i can't get the boot to open nor the Hood cover to release.
    Regards the hood cover - all works as should (windows go down) until i press the hood release button then nothing. (having to use the manual method)
    Regards the Boot - I can't get this to open, i can hear the central loncking actuiators working but on pressing or turning the lock with the key and depressing the darn thing just won't open.
    Is the issue with the wiring harnesses in the boot or a problem with the boot lock itself (have the plastiic link/s broken on one end of the rod that links the lock to the latch?
    Also how can i access / open the boot without drilling the lock out HELP PLEASE..
    Regards Rob
  2. Re: Audi Cab Boot Won't Open
    Jun 2007
    Gwent
    I don't know if the cab has the same boot catch, but on the coupe's: if the bump stops are set too high and there is too much tension on the catch, the catch does not release. If you press the hatch down when the barrel is pushed in, it may work.
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  3. Re: Audi Cab Boot Won't Open
    Apr 2007
    Worcestershire
    hi. If you've not sorted it yet - you may need to know that if the hood is not functioning properly in any way then the boot will not be allowed to open. I'm pretty sure that if the hood problem is solved then the boot will resolve itself.
    Hope you have it sorted already though.
  4. Re: Audi Cab Boot Won't Open
    May 2008
    Put the key in the boot lock and turn it just slightly to the left then push lock in quickly it will open after a couple of pushes then you need to check the black solenoid in boot lid rod goes to boot lock, part number 8g0959639,when its faulty it locks boot and only lets lid lift couple of inches
  1. Boot won't open?
    By deezal in forum Passat - B5 Forum - 1997 -2005
    Last Post: 31-01-2009, 10:20 AM
  2. My boot won't open
    By johnny_utah in forum Golf MK4 - 1999 - 2004
    Last Post: 25-01-2009, 01:28 PM
  3. Boot Wont Open Off Fob?
    By HappyS3Owner in forum Golf MK4 - 1999 - 2004
    Last Post: 13-08-2008, 02:07 PM
  4. The boot lid is not shut or open
    By maily in forum VCDS - General Questions
    Last Post: 22-04-2008, 07:04 PM
  5. boot lid won't open
    By maltrap in forum Beetle 2000-
    Last Post: 15-04-2008, 07:33 PM
