Thread: dead battery A4 B8
  1. dead battery A4 B8
    Nov 2008
    Hi everyone,
    My nightmare is dead battery.I had the same problem six times.The car does not start,does not give key and all doors are open des not closed.The car need battery support to start.The local audi services checked all unites on the car and they did not find any problem.They told me ' you must drive every day with high speed at least 30 km for everyday.the last one they updated 'battery management SW 27C5' software program.
    I hope the nightmare will stop.I think this problem was alive since the car was build but the local audi services in my city is not able to undersand the problem.
    I need a real management the problem.İf somebody have an idea please share us.
    thanks for kind corporation.
    Ramazan
  2. Re: dead battery A4 B8
    dont know the answer to your question but anything that happens more than once is to many times.... So in no way settle for this and contact Audi direct for assistance.
    you do NOT need to drive a car every day full stop, so ignore this stupid advice...
    A4 Monza Silver S-line, with parking+, crusie control, CD-Changer, 30inch drop with silver stitching
    Love it Love it Love it............
  3. Re: dead battery A4 B8
    May 2009
    Ostend
    I had the same problem. I never had a dead battery nor starting problems because I charged it when necessary, but the voltage was too low, even after a long drive. I still wondered if it wasn't caused by cold weather or not driving enough... When starting the car I got a warning message that the battery was too low and that driving the car would fix it. Yet it always started without hesitation. Finally contacted my dealer and they fixed it immediately. It is a known problem. I got a bigger battery and a few software updates. Some changes were for better battery charging or battery management. This was done after last winter. Maybe your problem is fixed too by now?
  4. Re: dead battery A4 B8
    Sep 2008
    any car built in the last 10 years should turn over no problem even if you haven't driven it in a month.
    Get onto Audi, don't bother with the dealer anymore. Let audi do that.
  5. Re: dead battery A4 B8
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    My B7 can stand up to 6 weeks while im working away and fires up first time,Jan 06 with origional battery.The dealer should be doing a full battery test,specific gravity and load test,and also a charging rate check.Another thing for them to do is check that the discharge when everything is turned off isnt over the recommended amps.The Canbus may not be `going to sleep` on a particular control unit when the car is locked.
  6. Re: dead battery A4 B8
    bodger1961 Guest
    Quote Originally Posted by Alan02 View Post
    I picked up my car and the battery was flat, same thing happend a week later. i had the car checked out everything was fine all systems shuting down and the alternator charging, i told audi this was not acceptable and they got in touch with the main audi cetre and they agreed to change it no problems since.
  1. 2000 beetle with dead battery in the mornings
    By guitarwarlock19 in forum Beetle 2000-
    Last Post: 02-06-2008, 05:58 PM
  2. dead battery
    By gibo in forum Audi A3 - Archive Topics
    Last Post: 05-01-2008, 12:44 AM
  3. Dead battery + Bonnet
    By Grind in forum Audi A4 - Archive Topics
    Last Post: 28-11-2007, 04:26 PM
  4. Battery dead again!! (bora uk)
    By 1stjetta in forum Bora - 1998 - 2005
    Last Post: 06-08-2007, 05:56 PM
  5. Ignition left on until battery dead!
    By michaelab in forum Audi A3 - Archive Topics
    Last Post: 30-05-2007, 12:56 PM
