Thread: Mk5 4Motion TDI 140 - Help needed
  1. Mk5 4Motion TDI 140 - Help needed
    Dec 2008
    Hi
    Im new to this site and need some advise :-
    Just bought a 55 plate VW Golf TDI 4Motion, I have a problem with the accelerate. When im on the motorway doing approx 70 mph in 6th gear and try to accelerate I get a loud ish noise and slight vibration (similar to when your in the wrong gear ie need to gear down) until you drive through it ie 80mph. Ive had a new CV joint in the front passenger side for a tight spot on the wheel. This has cured the bad vibration but not the noise !!!
    The noise also happens in 4th gear when accelerating sharply.
    Anyone got any ideas ???
    Help required - only have 1 week left on warranty.
    Thanks in advance.
    xx
  2. Re: Mk5 4Motion TDI 140 - Help needed
    Coventry
    take it back and insist on a tech bod to accompany you on a test drive and prove your point. when he acknowledges it, get him to repeat it infront of another member of the service team. that way, they have to acknowledge that the fault was reported before the warranty expired and must be repaired even if the warranty has expired.
  3. Re: Mk5 4Motion TDI 140 - Help needed
    Aberdeen
    Eh yeah, take it back and quick. As golfmk5gttdi says take a mechanic out with you so they can hear the noise also, don't let them take it out themselves or they'll just deny everything!!
  4. Re: Mk5 4Motion TDI 140 - Help needed
    Dec 2008
    Thanks for your reply.
    Does anyone know if it could be the prop shaft ?
    Jen xx
  5. Re: Mk5 4Motion TDI 140 - Help needed
    Jun 2008
    hi i have the same car , and i also had the same problem , it was almost as if i could not use 6th gear unless i was doing over 80 , CURE a full service done the job , also try staying in the lower gear slightly longer , but my noise and vibration have gone , i did consider prop shaft or the haldex system but that was not the case..............
  6. Re: Mk5 4Motion TDI 140 - Help needed
    Dec 2008
    Thanks for reply
    Can you let me know how many miles your car has done ? As mines only covered 30k.
    What type of service did you have ? Air, Fuel, Oil filter change ?
    Many Thanks
    Jen
  7. Re: Mk5 4Motion TDI 140 - Help needed
    Jun 2008
    hi my car had done 29k , the service was a full long life service all filters , oil and whatever else they do , i hope you find a cure for this nippy problem , i spoke with many car people and they told me to drive the car harder.............. hope this helps you..... i was going to sell mine and im glad i stuck with it , these cars are quite rare and one of the best golfs on the road , good luck
  8. Re: Mk5 4Motion TDI 140 - Help needed
    Dec 2008
    Help needed again.
    Just had a mechanic look at my car and they have tried removing the back prop shaft - to basically make it a 2 wheel drive. This has cured the problem.
    Do you think a new prop shaft will cure the problem or just the start of something worse ??
  9. Re: Mk5 4Motion TDI 140 - Help needed
    Dec 2008
    All sorted !!
    Needed a new prop shaft - fantastic service at statller sheffield.
  1. 4motion V6
    By george l in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-09-2008, 03:57 PM
  2. Needed Help Golf V6 4motion!!!
    By Danny1984 in forum Archive posts
    Last Post: 21-01-2008, 03:36 PM
  3. S3 rear diff on 4Motion Golf - help needed
    By Mokeylock in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 26-02-2007, 01:26 PM
