Thread: 1997 A3 1.6 AEH what relays and where??
  1. 1997 A3 1.6 AEH what relays and where??
    Mar 2008
    Essex
    hi,
    i suspect a relay problem ( not starting! but cranks ok )but i cant find information on all of them and what they control, any one know what sould be there???
    the under dash relay plate has the following relays...
    from left to right bottom row..No.53>No.18>No.379>No.167
    on top of these is one larger black relay No.175 that has a PCB inside and nine pin outs.
    are these correct??
  2. Re: 1997 A3 1.6 AEH what relays and where??
    Mar 2008
    Essex
    Quote Originally Posted by ali_b View Post
    hi,
    are these correct??
    after some searching i know Relay No.53 (Grey) controls horn electric mirrors/windows plus anything that works for about ten mins after ignition is switched off.
    Relay No.18 (Grey)is load reduction relay (this one has a resistor across the non switched pins)
    Relay No.379 (Black&has PCB inside)controls wash/wipe/blade park & intermitent control of front wipers.
    Relay No.167 (Grey) Fuel pump
    Not sure what the large black relay No.175 controls but may be alarm/central locking as it energises when pluged in whithout ignition on it also has a large PCB inside and twin relays inside plus nine pin out's.
    any one know what this controls?? ECU??
  3. Re: 1997 A3 1.6 AEH what relays and where??
    131 Post(s)
    1975 Post(s)
    Relay 175 is for the starter motor inhibitor on automatic cars only; you didn’t mention your car is an automatic.
    The ECU does not have a relay, power is from
    Pin 1 ignition live via fuse 29
    Pin 3 permanent live via fuse 10
    Pin 22 cranking live from the ignition switch.
    Have you done a fault code read?
  4. Re: 1997 A3 1.6 AEH what relays and where??
    Mar 2008
    Essex
    hi crasher, Thanks for your quick reply.
    yes it is an automatic, i have done a fault code read with the following DTC's
    Wednesday, 03 December 2008, 15:26:02
    VAG-COM Version: Release 409.1-US
    Control Module Part Number: 06A 906 019 D
    Component and/or Version: 1.6l R4/2V SIMOS AT2153
    Software Coding: 04030
    Work Shop Code: WSC 06313
    2 Faults Found:
    01177 - Engine Control Unit
    37-10 - Faulty - Intermittent
    00537 - Lambda (Oxygen Sensor) Regulation
    18-10 - Upper Limit - Intermittent
    the occasional cranking but no start i suspect the ECU has an intermittent fault is this common?
    i have checked cleaned retightend the immobiliser earth and any other earth point's i could find.
    No start's seem to be compleatly random more when cold/damp althogh has when warm to its got me baffled!
    The O2 sensor has been replaced but fault still returns, the car is high mileage 128,000M and seems to be pinking throughout the entire rev range under light acceleration/increased load.
    i cleaned and re adapted the TB and this made a massive improvement in response and acceleration/idle, still pinks although not as much, there doesnt appear to be any obvious vacume leaks, i will try a new fuel filter, then fuel pressure regulator if that fails to improve then injector's may need cleaning.
    if it does start it will on first try if not then 10+ attemps or jumping it seems to help still might take 4+ trys (it has a new battery)
    Any advise on what i can try before sending ECU for testing/replacement greatly received!
  5. Re: 1997 A3 1.6 AEH what relays and where??
    131 Post(s)
    1975 Post(s)
    The lambda code is of no inerest at the moment, the other code means
    01177 Engine control unit Defective, Engine will not start. Replace engine control unit
    which is straight from the VW workshop manual.
  1. Sharan Relays
    By dazmac in forum Touran - Sharan - Caravelle
    Last Post: 05-01-2010, 09:05 PM
  2. Window Relays ?
    By marvinds in forum Golf MK3 - 1993 - 1999
    Last Post: 29-07-2008, 09:05 PM
  3. Why do I have 2 x # 370 relays - picture
    By headache56 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-06-2008, 10:36 AM
  4. relays
    By aa303 in forum Golf MK3 - 1993 - 1999
    Last Post: 27-04-2008, 07:47 PM
  5. relays golf diesel 1.9 1997
    By donald.symons in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 27-07-2007, 04:26 PM
