Thread: Mk4 Brakes
  1. Mk4 Brakes
    Body in Cardiff...spirit in Ireland
    I know this has been covered but here goes.....
    I decided to change my disc's, pads, rear calipers and brake fluid to make the car perfect. I got the parts and left it to my local mechanic who has always done ok for me before now.
    When i went to collect the car, he said he couldn't get the pedal feel back and thought i needed a new master cylinder. This seemed odd as the master cylinder had been fine the day before.
    Anyway, after googling and looking on here, there seems to be a long bleed procedure which you need to go through if any air gets in the system.
    Thats ok...so off i went to find someone with a little skill and vag-com to do the work. The problem is, there isn't anyone in Cardiff who has any skill or equipment. I went to 'Cardiffs VW and Audi Specialists' who said nobody has that kind of software except VW. He wouldn't accept that 2 friends I have in Dublin have this setup just for tinkering.
    Anyway, I've booked it in to VW this afternoon-I'm not sure the VW guy knew what i was talking about either.........
    Sometimes I wonder why I bother trying to keep the car in tip top condition.
  2. Re: Mk4 Brakes
    Sep 2008
    Birmingham
    Quote Originally Posted by davegilsenan View Post
    If you don't keep brakes tip top, problems tend to occur ie. total loss on insurance, maybe a touch of permanent injury etc.
  3. Re: Mk4 Brakes
    nottinghamshire
    i have a simular problem too,
    i had my rear pads and discs changed and also a new caliper becuase it had popped out, and i cant find anyone who can bleed the brakes properly. the garge where the brakes were changed bled the brakes but still felt spongy then i went to quick fit for a full bleed, there a little better after quick fit had a go but there still not how they were.
    what is the problem with bleeding the brakes
    why is it so difficult
  4. Re: Mk4 Brakes
    I think the problem is if any air at all gets in the system, especially into the ABS pump, then its really difficult to get out.
    I took mine to VW and it took the guy 3 attempts but he finally got it sorted. £50 well spent.
    Its a procedure with a number of steps where you need Vag-com or a VW dealer to plug the car in.
    Kwik-fit will just bleed it with a pressure bleeder.
    My brakes are brilliant now!
  1. Brakes
    By shahid1973 in forum Bora - 1998 - 2005
    Last Post: 06-02-2008, 09:24 AM
  2. Brakes Help!!
    Last Post: 08-01-2008, 02:21 PM
  3. Upgrade A6 brakes to S8 brakes
    By mmm777 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 15-09-2007, 10:15 PM
  4. S3 Brakes
    By rdj_s3_quattro in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 10-07-2007, 02:57 PM
  5. GT TDI Mk4 Brakes
    By benGT in forum Golf MK4 - 1999 - 2004
    Last Post: 28-06-2007, 07:56 PM
