Thread: Faulty Oil Pressure Warning??
Results 1 to 10 of 10
  1. Question Faulty Oil Pressure Warning??
    Feb 2007
    Got an odd fault on a 1999 A6 TDi 1.9:
    Turn on ignition, dashboard goes through self check including illuminating the oil warning light (so the bulb works), OK so far....
    I can't get the oil warning light to come back on, even when it should,eg stall the engine or disconnect the pressure switch..!!!!!
    Checked the pressure switch (single wire type), shows open circuit (to earth) when engine not running, and short circuit (to earth) when the engine is running. So the switch is OK.
    Checked the wire to the switch; disconnected from the switch shows battery voltage with engine running (still no warning lamp on dash), so the wire is connected to something at the other end (so not a broken wire).
    Anyone seen this problem before??
    (Would be nice to know if I loose oil pressure..!!!)
  2. Re: Faulty Oil Pressure Warning??
    Jul 2009
    Bergen, Norway
    There are two sensors.
  3. Re: Faulty Oil Pressure Warning??
    131 Post(s)
    1978 Post(s)
    It doesn’t work like that, it is a dynamic system. If you disable the engine and crank it over for a prolonged period (such as after changing a fuel filter) the warning will come on.
  4. Re: Faulty Oil Pressure Warning??
    Feb 2007
    Hi, thanks for the replies.
    Karlaane, Where is the other sender?
    Crasher, If you are cranking the engine the oil pump will turn, and should (unless worn, or worn crank bearings) provide enough pressure to keep the low pressure light off.
    I had the engine running and disconnected the wire from the switch, still no warning light?
  5. Re: Faulty Oil Pressure Warning??
    131 Post(s)
    1978 Post(s)
    Not enough pressure under cranking, the crank speed is too slow. Often on here we have people whose cars won’t start for one reason or another and they often add that the oil pressure warning went off under prolonged cranking, which is normal.
  6. Re: Faulty Oil Pressure Warning??
    Feb 2007
    So is the only way of testing the oil presure low warning circuit by cutting off the diesel supply, and cranking the engine for a long period?
    There must be a test that is a little easier on the bearings/starter motor?
  7. Re: Faulty Oil Pressure Warning??
    Jul 2007
    Cheshire, or my A6
    Not sure if this is quite what you mean...
    But on all 3 of my VAG TDIs, when I turn the ignition on the oil light illuminates very briefly and then goes out regardless of whether I start the engine or not. Even after stalling, the oil light will not illuminate.
    I believe it to be normal.
  8. Re: Faulty Oil Pressure Warning??
    131 Post(s)
    1978 Post(s)
    Using VAG-COM or similar, Measuring Blocks 08, Display Group 001 Display Zone 3 shows oil pressure switch 2 status, with a registered version of VAG-COM, visual and audible warnings can be triggered in Output Tests 03. There is no Audi method of testing the light I know of, just the switch and the pressure itself. The switch should close its contact at 0.75 to 1.05 bar.
  9. Re: Faulty Oil Pressure Warning??
    Feb 2007
    Thanks Crasher, I will give that a go.
  10. Re: Faulty Oil Pressure Warning??
    Jul 2009
    Bergen, Norway
    Quote Originally Posted by Alas View Post
    I am not quite sure on 1.9, but on a 2.5 there are two sensors, both sensors are on the left side of engine block below and slightly behind the thermostat housing. One is large and has two plugs, it is the oilmanometer and oil lamp, the other is for the oil lamp. One works at low rpm, the other high.
    K
  1. Oil Pressure Warning Light
    By JEG in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 27-06-2013, 10:04 PM
  2. Faulty alarm on 51 reg A4
    By outside 12 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 23-11-2007, 10:40 PM
  3. ?faulty maf
    By pinback2001 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 06-05-2007, 08:08 PM
  4. Passat 1.8T Oil Pressure warning
    By jamiek in forum Archive posts
    Last Post: 28-03-2007, 06:34 PM
