Thread: VW Polo 1.4 Stiff Gear
  1. VW Polo 1.4 Stiff Gear
    Dec 2008
    Hi Guys, I previously owned a 1995 1.3 VW Polo, which I had used for 5 years with 165000 miles on the car, the bodywork was looking a bit tarty, and I stupidly decided to give it away to a relative. I have just "upgraded" to an R-REG (1998) 1.4, and here lies my problem, on my way to work today after less than 3 days of owning the car, the exhausts gave way, had to get a new cat and middle bit from the quickfit + rocker gasket at a cost of £286. The last owner has parked the car for the past year as I could tell from the last 2 MOTs........
    My question is that the gear appears to be a bit stiff, compared to the one I have just given away, is this normal on 1.4 as opposed to my previous polo, or is there something else I should be worried about?
    Thanks.
  2. Re: VW Polo 1.4 Stiff Gear
    7 Post(s)
    Could be all manner of things but the most likely is a low oil level in the box. Have you checked and topped it up?
  3. Unhappy Re: VW Polo 1.4 Stiff Gear
    Dec 2008
    Thanks very much for that...... sorry if I sound a bit dim, can I check the gearbox oil as I would check the engine oil, or is this something that requires tools etc?
  1. Bora 99V gear change stiff problem
    By psxnut in forum Bora - 1998 - 2005
    Last Post: 23-03-2009, 08:04 PM
  2. Question Stiff Gear Shift
    By damjee in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-05-2008, 07:43 PM
  3. Stiff 2nd Gear
    By David8831 in forum Golf MK2 - 1984 - 1992
    Last Post: 19-01-2008, 05:26 PM
  4. Footwell water leak / first gear is stiff
    By stejuk in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 02-06-2007, 11:03 PM
  5. Passat Gear Selection Stiff
    By chrisball666 in forum Passat - Archive Topics
    Last Post: 21-04-2007, 10:57 PM
