Thread: Electric Mirror Control Switch
  1. Electric Mirror Control Switch
    Feb 2007
    Oxted, Surrey
    Being a clumsy clutz the other day I broke the control knob off the Electric Mirror Control Switch on my 2001 Passat.
    I’ve been relieved of £23 for my stupidity by VW. Has anyone replaced these switches before. It looks like it should pop out with a gentle lever with a screwdriver, however when I try it doesn’t want to budge – maybe I need more force, but don’t want to wreck the surrounding plastic. Any ideas appreciated.
    Marc
    Oct 2005
    Quote Originally Posted by Rhostine View Post
    Marc
    I have a feeling you need to remove the door panel - prising the switch out results in a lot more damage.
    Nov 2006
    derbyshire
    Remove the dorr panel. Pretty sure if you go at it with a screwdriver from the outside you will damage the lugs that hold the switch in position.
    Caterham, Surrey, UK
    Quote Originally Posted by gresty View Post
    That's correct - you need to remove the door panel, as the switch is held in by metal tabs bent around the hole. Prising it with a screwdriver will damage the door panel
    Andy
  1. Cruise Control / Climate Control
    By Cian_ie in forum Archive posts
    Last Post: 27-01-2008, 08:47 AM
  2. Golf Mk4 Electric Mirror switch
    By mydogsgotnonose in forum Golf MK4 - 1999 - 2004
    Last Post: 25-05-2007, 11:23 AM
  3. Locating Central control unit and window control unit
    By AdamPhillips88 in forum Touran - Sharan - Caravelle
    Last Post: 23-04-2007, 08:59 PM
  4. Golf TDI electric wing mirror problems...
    By bigwint in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 17-03-2007, 04:01 PM
  5. Audi A6 Mirror Switch
    By ggwinner in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 19-02-2007, 11:57 PM
