Thread: Interior Lights.
Results 1 to 8 of 8
  1. Cool Interior Lights.
    Jan 2006
    Manchester
    Hi all, hope you can help, my interior lights dont work when opening the rear doors on my 2000 110 TDI. Is this usual?, when I open the front doors all the lights work ok. How do the sensors work so I can check them and/or the wiring etc.
    Jez.
    Oct 2005
    Er, you don't state what car this is for.
    Perhaps armed with that info, we'll be able to help
  3. Interior Lights.
    Jan 2006
    Manchester
    Sorry its a Passat, Doh!!
    Oct 2005
    Moved to the Passat section
  5. Interior Lights
    Feb 2007
    Jez
    Did you find out how to fix the problem with your interior lights - mine wont work with any door open or the key out of the iginition or unlocking it - any help ?
    Jan 2006
    Manchester
    HI Graham I bet ur wires have coroded in ur passenger footwell. It'l be the red wire that has rotted away. Cut off the decayed wire and join it back together, it'l probably work then, you'll need to find out where the water ingress is coming from though. Usually the blocked battery tray drainers, remove the battery you'll see them, or under the pollen filter housing, you'll have to seal it with siicone sealant, or ur windscreen's leaking. I had the same problem just like many other passat owners. Hope this helps, if not drop me another line. No luck with my lights as it seems a little complex, they do work, its just when I open the rear doors the lights don't come on, they're fine when I open the front doors.
  7. Unhappy Interior Lights
    Feb 2007
    Hi Jez
    I managed to get the carpet out - took the seat out too and got it all dried out. The CCU conections with the little metal "spuds" were coroded and one was broken - no. 21. I thought this was the problem with the interior light but when I reattached a wire and the meal rod going into the circuit board it still made no difference. I am baffled! the board could be shot and thats the reason i dont know? I was the blue wire no 21 that had the broken "spud" not the red one.
    All the other wires seem to be ok. I dont know what else to do.
    One other thing was that when i took the seat out i had to disconnect the airbag wires - when i put the seat back in i reconnected it but now I am getting a warning on the dash with "airbag fault" showing. I dont now know how to cancell it - does any one have any suggestions?
    Apr 2007
    Lancashire
    Ah! I got this when the hands-free fitter unplugged the airbag warning lamp on the radio surround.
    As a matter of interest, did you do this with the ignition on or off?
    A ******* will charge you £88 to reset it or an independent will charge £25.
  1. interior lights
    By gibo.drum in forum Chat - Anything with wheels
    Last Post: 18-02-2008, 09:43 PM
  2. Pulsing interior lights? What's that all about then?
    By Niall76 in forum Archive posts
    Last Post: 23-02-2007, 10:09 PM
  3. Passat Interior Lights
    By JASTONV in forum Passat - Archive Topics
    Last Post: 17-12-2006, 09:31 PM
  4. Passat all interior lights on
    By d.wadswoth in forum Passat - Archive Topics
    Last Post: 18-11-2006, 01:22 PM
  5. Dodgy Interior Lights.
    By Jez. in forum Chat - Completely Off Topic
    Last Post: 29-03-2006, 08:41 AM
