Thread: Camshaft Position / Hall Sensor 17746 - (G40): Open or Short to Plus
  1. Exclamation Camshaft Position / Hall Sensor 17746 - (G40): Open or Short to Plus
    May 2007
    South East London (West Thamesmead)
    Hi guys
    could anyone help shed some light on a problem i have had for a while now
    17746 - Camshaft Position Sensor (G40): Open or Short to Plus
    P1338
    this will come up and the engine mangement light comes on - it actually disapers then return a couple of days later..?
    I am told that the fault code refers to "bank one".
    I have a V6 2.4 A4 Avant (x-reg 2000) which has two banks i assume - how do you know which is bank one and which is bank two?
    I have had a look at the hall sensor at the front of the engine block opposit side to the oil filling plug (looks ok), but find the second hall sensor difficult to access?
    I would say the car run very well (as far as i can tell) - but could ther be a timing problem? or can it only be:
    1. Faulty hall sensor
    2. Faulty wire/plugs going from hall sensor to ecu
    3. Faulty Ecu
    what can i do to "kill" this fault?
    any suggestions would be greatly appriciated
  2. Re: Camshaft Position / Hall Sensor 17746 - (G40): Open or Short to Plus
    Chester-le-Street, United Kingdom
    Quote Originally Posted by thor_wulff View Post
    Hi guys
    P1338
    3. Faulty Ecu
    in my experience the banks have been known as left or right looking from the flywheel end,but in this case i would hazard a guess at bank one being the "odd" cyls,1-3-5,and bank two being the "even"cyls,2,4,6.
    no 1 cyl being in front of no 2?
    i would say that fault 1 is possible,fault 2 is possible, but fault 3,ecu, highly unlikely. likewise a timing fault or you would have big probs starting,or running without smoke.
    just my opinion,
    regards,
    stewy.
    first time i was up a ladder i was down a well
    4th cog,--two to go
  3. Thumbs up Re: Camshaft Position / Hall Sensor 17746 - (G40): Open or Short to Plus
    May 2007
    Thanks stewy - I might try to swap the Hall sensors around and see if the fault moves to bank two - if so it must be the sensor - if not it is most likely the wire/conection - still not sure which is bank 1 though...
    .............................Hall Sensor
    .................3_____6
    .................2_V6__5
    .................1_____4
    Hall Sensor
    Front of car
  4. Re: Camshaft Position / Hall Sensor 17746 - (G40): Open or Short to Plus
    Hall Sensor
    Front of car
    think that's the hall sensor diagram,not the engine.
    looking from the side of the engine,look for the front most plug lead,or diesel injector pipe.
    that will be number one cylinder,followed,on that same side by no3 then no5 cyl.
    that will be no 1 bank.
    the other bank will have 2-4-6.
    regards,
    stewy.
    4th cog,--two to go
  1. 00515 Hall Sensor G40 No Signal - HELP
    By mitov in forum VCDS - General Questions
    Last Post: 12-12-2010, 03:16 PM
  2. Fault code 0203 (Hall effect sensor out of range)
    By Cawte12345 in forum Touran - Sharan - Caravelle
    Last Post: 08-12-2009, 01:37 AM
  3. Please Help Hall Sensor VAG 06A 905 161 B Availability
    By doubledeclutch in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-08-2008, 11:32 PM
  4. Question A4 Hall sensor?
    By marty72 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-05-2008, 01:07 PM
  5. Camshaft Sensor (G40) - where is it?
    By Mat456 in forum Golf MK3 - 1993 - 1999
    Last Post: 25-12-2007, 11:00 AM
