Thread: glovebox hinge broken
Results 1 to 8 of 8
  1. glovebox hinge broken
    Sep 2007
    carlisle
    Hi guys, left hand side hinge has broken on my 2002 a4 avant. Do i have to replace the whole door or are the hinges separate ? Also does the glovebox have to come out ?
  2. Re: glovebox hinge broken
    Jun 2008
    You can either:
    1) Make metal brackets to support the broken hinge
    2) Buy a new glovebox hinge which is the inner part of the lid. You have to remove the outer cover and lock to install back into the new part
    3) Look on ebay for one which is what I did. 99p I got mine for plus 12 delivery...bargain
    J
  3. Re: glovebox hinge broken
    Atherton, Lancashire
    You know i just logged on to ask this very question! This happened to mine the other day! Gutted cos its just one thing after another!
    Only had the car for 3 months and so far its not all thats its cracked up to be! Have had a coolant leak, then just had to replace air intake sensor then a cam sensor n now gearbox is crunchin in 1st n 2nd! Wish i'd stuck wi my 10 year old A3 it was immaculate n problem free!
    2004 A4 1.8T Ltd Edition! Drive it like you stole it!
  4. Re: glovebox hinge broken
    Mar 2007
    Lancashire
    S-line, I have the clunky 1st to 2nd gear to. It's ok once warm or a few miles. I checked my gearbox oil and noticed that it was 7mm below the line. I think the tolerance is 0-7mm so I may top up and see if any difference is noticed.
    I had the glovebox hinge brake. I got one from another member for a few pounds. When you get a new one, spray some WD-40 inside the piston mechanism so it doesn't happen again! Another design fault from Audi!!!
    A4 1.9TDI 160bhp Sport - 2001 (51)
    Re-map by more-bhp.
    TT 3.2 V6 DSG quattro 270BHP - 2003 (53)
  5. Re: glovebox hinge broken
    Sep 2008
    London
    Quote Originally Posted by a4_jim View Post
    You can either:
    J
    My left hand side hinge is broken as well, i went to audi and they quoted me some silly price to replace the glovebox door
    A4jim could you shed any more detail on points 2 & 3, on ebay i seem to only see the whole lid does this include the hinge,
    Audi A4 2004 1.8T S-line (190) Multitronic Misano Red
    _______________________________
    Retrofitted: cruise control/(Hazzydays)
  6. Re: glovebox hinge broken
    Jun 2008
    The hinge is actually is part of the inner section of the glovebox lid. If you buy from Audi you can buy just that section and swap over the lid and lock.
    If you find any on ebay it will be the whole lid and inner section with lock.
    J
    Quote Originally Posted by Mr_Meeks View Post
  7. Re: glovebox hinge broken
    Quote Originally Posted by Marco34 View Post
    Yeah it still grinds when warm also unfortunately! Synchros are worn so its goin into garage tomoro so expectin to replace gearbox for around a grand!!!
  8. Re: glovebox hinge broken
    Nov 2008
    The part number of lid with hinge is in 2 parts
    the pin
    8E0 857 169
    and the lid
    8E1 857 124
    That should help you
  1. Tiptronic Selector Broken/Stereo Mounting Broken
    By anthonyendsor in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-10-2008, 10:21 PM
  2. 06 sharan top glovebox broken hinges
    By davelebarr in forum Touran - Sharan - Caravelle
    Last Post: 15-09-2008, 06:56 PM
  3. Broken Boot Hinge on 2003 Passat
    By JB7 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-04-2008, 10:10 PM
  4. glovebox lock broken
    By crudbuster in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-01-2008, 01:47 PM
  5. 4motion problems (leaks/damp, broken glovebox, ESP light)
    By Toiletduck in forum Golf MK4 - 1999 - 2004
    Last Post: 22-12-2007, 05:06 PM
