Thread: asr abs lights
Results 1 to 10 of 12
  1. asr abs lights
    Dec 2008
    tarbolton
    i am new to this forum and having a problem with ma car. 2001 golf gti 1.8t asr and abs lights come on when stoped. switching ignition off slightly when driving keeps lights off til i stop again then they come back on. only just started this week. any ideas?
  2. Re: asr abs lights
    135 Post(s)
    2026 Post(s)
    A fault code read will tell you what is wrong but that is an odd symptom.
  3. Re: asr abs lights
    Dec 2008
    tarbolton
    take it i need to put it in a garage to get a code read?
  4. Re: asr abs lights
    Quote Originally Posted by sjcelliot View Post
    or purchase a scanner/vagcom or find someone who's got a copy of vagcom/scanner nearby to you
    Fill out your location field on your profile so we can try and help you
  5. Re: asr abs lights
    Dec 2008
    tarbolton
    location field filled out.
    problem started on a very cold morning up here had hoped it may be related to weather but its a slightly warmer now , still below freezing tho
  6. Re: asr abs lights
    if it's just a basic scanner you need to see what fault codes you have and if nobody nearby can help out, I can lend you one for a short while
  7. Re: asr abs lights
    Dec 2008
    tarbolton
    i am not entirely sure wot it is i need to get to read the error codes
  8. Re: asr abs lights
    you'll need a fault code reader (like the one I've offered to lend you) or a copy of vagcom, with a vagcom (or compatible) lead, along with a laptop.
    it's really very simply once you get into it.
  9. Re: asr abs lights
    Dec 2008
    tarbolton
    I appreciate you offer of loan of the code reader.
    i have the laptop side of things covered but how do i get the vag software and compatible leads so i dont have to trouble you
  10. Re: asr abs lights
    Mar 2008
    Just Cumbria now.
    You need a special lead that plugs into the laptop and then into the car's diagnostic port.
    Eshrules-Enterprises can supply you one of these for ~£15, and then you need to go to Ross Tech and get hold of a copy of VAGCOM software (this is available as a basic shareware or a more functional version for $99).
    You can then read the faults on the vehicle, and if you reprt back here, I'm sure someone will be able to tell you want they mean.
    HTH, Hex
    Nothing to see here, move along..
  1. ABS, Glow plug, Traction control lights Flashing and no brake lights
    By bbq365 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-02-2011, 06:15 PM
  2. Led Lights In Front Light Unit Or Fog Lights???
    By bigbadsexy in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 18-09-2009, 07:28 PM
  3. 2003 Audi A4-Brake Lights & Rear Lights
    By csheehy35 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-11-2008, 10:12 PM
  4. Flashing glow plug lights - break lights ok?!
    By Jonny Chee in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-06-2008, 07:27 PM
  5. led side lights and number plate lights, not working
    By adamk in forum Audi A3 - Archive Topics
    Last Post: 02-04-2008, 07:37 PM
