Thread: engine smoke, golf 1.6se and not starting 1st time
  1. Re: engine smoke, golf 1.6se and not starting 1st time
    Aug 2008
    no warning lights.
    fuel economy varies... sometimes around town im getting 22/23mpg and sometimes i'm getting 28/29mpg... But on the motorway its not bad I get around 35/36mpg.
    Is this right?
  2. Re: engine smoke, golf 1.6se and not starting 1st time
    Nov 2008
    MPG sounds about right
    When was the last service done?
  3. Re: engine smoke, golf 1.6se and not starting 1st time
    Aug 2008
    Last service was done at kwik fit, but not to sure if this was done properly. Do you think a service maybe the answer?
  4. Re: engine smoke, golf 1.6se and not starting 1st time
    Nov 2008
    Beverley East Yorkshire
    what colour is the smoke? is the car loosing any oil? have kwikfit overfilled it?
  5. Re: engine smoke, golf 1.6se and not starting 1st time
    Aug 2008
    Smokes white, this happened when I was trying to start it. It only happened the once, and a few months after kwik fit were let loose on it.
  6. Re: engine smoke, golf 1.6se and not starting 1st time
    Nov 2008
    Dont think its service related at that length of time.
    I would first get the injectors and pipes looked at and a pressure test wouldnt go amiss!
    If the injectors/pipes are leaking it wont run to well and you may well get some smoke.
    Do you get any excessive black smoke from the exhaust?
  1. White smoke on cold starting
    By willster in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-03-2013, 10:57 AM
  2. Black smoke on hard acceleration (Not every time)
    By t_basham@hotmai in forum Vento - 1994 - 1998
    Last Post: 24-10-2007, 06:07 PM
  3. Help!! Poorly engine and not much time
    By tut_gareth in forum 80 - 90
    Last Post: 23-07-2007, 12:44 PM
  4. 2.4 transporter still got issues starting + smoke
    By allankayak in forum The Commercial Range
    Last Post: 19-02-2007, 05:57 PM
