Thread: clutch problem
Results 11 to 20 of 22
  1. Re: clutch problem
    nottinghamshire
    i have had exactly the same problem
    had the master done then the bleed housing and all new o rings, then finally it was the slave...
  2. Re: clutch problem
    Nov 2006
    How much did it cost to get the slave done?
    2003 Passat 1.9 SE Sport TDI 130
    2002 MK4 Golf 1.9 GT TDI 130
  3. Re: clutch problem
    135 Post(s)
    2038 Post(s)
    It will eventually fail completely but I have known them do this for at least a year before failing. Unfortunately, with yours being a six speed, it may not be the master cylinder, it is possibly the concentric slave cylinder/ release bearing but I suggest doing the master cylinder first to see if that cures it.
  4. Re: clutch problem
    nottinghamshire
    Quote Originally Posted by d@ve View Post
    i think it was ?120 labour, with the option to put a new clutch in at the same time..
    the slave was about 40 from vw
  5. Re: clutch problem
    135 Post(s)
    2038 Post(s)
    As I said in my previous post about this, I don’t know how your mechanic survives on the labour he charges, VW quote an unrealistic 510 time units on that job and it takes longer, it takes me a full day.
  6. Re: clutch problem
    nottinghamshire
    Quote Originally Posted by crasher View Post
    as I Said In My Previous Post About This, I Don’t Know How Your Mechanic Survives On The Labour He Charges, Vw Quote An Unrealistic 510 Time Units On That Job And It Takes Longer, It Takes Me A Full Day.
    I Dunno Why Either?
    I Got It Done At A.f.d. Mapperly Top. But He Has Done A Few Clutchs Before On The 6 Speed Box's, So He Knew What He Was Taking On, Plus He Is A Friend Of The Family, I Think He Would Usually Charge 150-175
    He Did It On A Saturday Too, Which Is A Half Day?
  7. Re: clutch problem
    #17
    135 Post(s)
    2038 Post(s)
    Yes I know them, I did a couple of jobs for them a few weeks back.
  8. Re: clutch problem
    #18
    Dec 2008
    hi there new to the form and need some help!!!
    drive a golf gti turbo on an 02 plate,on my way to work this morning was about to pull away and ma car would not go into gear.not sure if its the clutch or the gearbox.when the cars not started selecting a gear is no problem but the clutch feels fine too.
  9. Re: clutch problem
    #19
    nottinghamshire
    Quote Originally Posted by ross87green View Post
    are you getting the same problems as everyone else
    soft pedal or pedal going to the floor?
  10. Re: clutch problem
    #20
    135 Post(s)
    2038 Post(s)
    That is a clutch problem but it is odd that the clutch feels fine, it sounds as though the release bearing arm has failed but I normally only see that on 5 speed boxes with heavy duty clutches.
  1. Please Help Possible clutch problem
    By HUK in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-09-2008, 08:45 AM
  2. SOS Please help clutch problem
    By lazy_boy in forum Audi A3 - Archive Topics
    Last Post: 26-08-2008, 10:47 PM
  3. Clutch problem
    By jonnyturbo in forum Golf MK4 - 1999 - 2004
    Last Post: 10-08-2008, 07:36 PM
  4. Please Help Clutch Problem, i think!
    By TWEET in forum Golf MK4 - 1999 - 2004
    Last Post: 17-05-2008, 10:25 AM
  5. clutch problem
    By Bizzie in forum Octavia
    Last Post: 03-02-2008, 12:03 AM
