Thread: Windscreen washer spray adjustment
  1. Windscreen washer spray adjustment
    I have a Golf mkV TDI and want to know if it is possible to adjust the actual spray from the windscreen washers.
    The near-side spray works well, however the off-side spray is more of a jet can this be adjusted to spray a wider area?
    I have had a look but cannot see a way to adjust it. I have also checked and can't see that it is blocked in any way.
    Hope this makes sense and appreciate any advice on this.
    Clarkey
  2. Re: Windscreen washer spray adjustment
    Bath, Somerset
    It will probably need replacing. They aren't expensive, under £10 from VW.
  3. Re: Windscreen washer spray adjustment
    Quote Originally Posted by dubcruiser View Post
    Thanks for your reply, I didn't think there was much I could do apart from replace - at least it's cheap!
  1. Question Rear windscreen washer
    By cornishboy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-07-2008, 08:57 PM
  2. Windscreen washer nozzles
    By broket in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 15-05-2008, 08:38 AM
  3. Drivers side washer.spray won't work!
    By dubtastic in forum Golf MK3 - 1993 - 1999
    Last Post: 16-04-2008, 07:18 PM
  4. S4 Spray Type Washer System
    By Stevieb3 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-02-2008, 06:05 PM
  5. B6 Windscreen spray jets on mk4 golf?
    By mobitune in forum Chat - Anything with wheels
    Last Post: 20-10-2007, 11:39 PM
