Thread: constant full boost!!! boost leak? MAP sensor?
  1. Angry constant full boost!!! boost leak? MAP sensor?
    May 2008
    used VAG-COM the other day to log the specified boost against the actual boost. there is a major difference in values as you can see. (see attached images)
    I jacked up the car and got under it while running. I set vag com to cycle through the N75 test cycle. when i looked at the actuator it was not moving at all. i pulled off the vacuum line and the actuator rod shot back. the vacuum line was sucking really hard. so this makes me believe that my car is constantly fully boosting. Is this normal? would could cause this to happen.
    also when the car is idling, the specified boost is at 1336mb, where as the actual is aprrox 1000 all the time. it does bob around abit when reving up.
    the symptoms from driving are,
    1. excessive fuel consumtion. i get 35mpg max
    2. lack of low end power.
    3. hard to start when cold.
    4. smell of unburnt diesel alll the time.
    this is a weird, and im totally baffled to what is causing it.
    the car has had:
    new turbo
    engine coolant sensor
    fuel temp sensor
    MAF sensor
    cambelt changed
    egr and intake cleaned
    please help!!
  2. Re: constant full boost!!! boost leak? MAP sensor?
    Mar 2008
    Do you mean the vacuum line from the intake manifold was sucking at idle with no throttle applied?
  3. Re: constant full boost!!! boost leak? MAP sensor?
    May 2008
    No, i mean exactly what i say, the vacuum line to the turbo actuator is constantly sucking at idle. it wont let me do the N75 tests because of this. when u pull the hose off the turbo actuator, the rod shoots straight back and the turbo stops boosting.
    with all this cold weather, the car starts on 3 cylinders and its burning oil for a few mins then stops. these look like signs of worn injectors seals. going to do a compression test soon. does anybody know what sort of compression ratios i should be getting?
    I want to make sure that its the injector seals before buying them because they are £16+VAT each at VW!
    please pick ur brains and help!
    shawn
  4. Re: constant full boost!!! boost leak? MAP sensor?
    Nov 2016
    ireland
    To me this problem sounds like a faulty map sensor. I have the same symptoms but I am using the diode mod which means i have the map sensor disconnected.
  5. Re: constant full boost!!! boost leak? MAP sensor?
    131 Post(s)
    1973 Post(s)
    In Basic Seings 011 the actuator is opened and closed by the ECU operating the N75 valve so the actuator should cycle off and on every ten seconds or so and you can see the actuator respond to this by full scale defelection each way.
  6. Re: constant full boost!!! boost leak? MAP sensor?
    Nov 2017
    Scotland
    25 Post(s)
    Quote Originally Posted by boratdi150 View Post
    No, i mean exactly what i say, the vacuum line to the turbo actuator is constantly sucking at idle. it wont let me do the N75 tests because of this. when u pull the hose off the turbo actuator, the rod shoots straight back and the turbo stops boosting. with all this cold weather, the car starts on 3 cylinders and its burning oil for a few mins then stops. these look like signs of worn injectors seals. going to do a compression test soon. does anybody know what sort of compression ratios i should be getting? I want to make sure that its the injector seals before buying them because they are £16+VAT each at VW! please pick ur brains and help! shawn
    I think I would be getting a vac Gage on the actuator and make sure its set to open at correct pressure(as new turbos are not always set up correctly from new,sometimes even from the dealers !)--start to open at around 2--fully open by between 16--18--ya can get exact numbers from google !!
  1. Low boost
    By smr510 in forum VCDS - General Questions
    Last Post: 14-11-2008, 11:10 PM
  2. Audi S4 Boost Pressure Sensor
    By wadi110 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-10-2008, 10:09 PM
  3. Boost Pressure Sensor - need help with wiring
    By turbobugger in forum Beetle 2000-
    Last Post: 17-04-2008, 06:26 AM
  4. Boost Leak?
    By FOOTSY in forum Polo - Derby - Lupo - Fox
    Last Post: 17-01-2008, 10:22 PM
  5. A3 Boost
    By t0m541 in forum Archive posts
    Last Post: 27-03-2007, 09:01 PM
