Thread: Airbag current too high
Results 1 to 9 of 9
  1. Airbag current too high
    Hi all,just enabled p/s airbag and auto locking but now vag-com is telling me the current is to high to the front passenger side airbag,is there something else needs to be removed that someone might know of...thankyou
  2. Re: Airbag current too high
    would there have been a resistor put in at the dealers that needs removed
    Ross Tech VAG-COM KII-USB Interface
  3. Re: Airbag current too high
    Jun 2008
    The Wee County
    https://www.vwaudiforum.co.uk/forum/s...disable+airbag
    Looks like they do fit a resistor in some models. Don't think I'd like to tamper with anything to do with airbags myself though as the consequences if you get it wrong could be fatal.
  4. Re: Airbag current too high
    Ambler, PA, USA
    Quote Originally Posted by ian falls View Post
    Let's review Ohm's law: E=I*R where E is the voltage, I is the current, R is resistance.
    So, the available voltage in the system is battery voltage - let's call it 12 volts. If the current is out of spec - high, then the resistance must be out of spec low because as the current goes up, resistance must go down for the same voltage.
    You do not have extra resistance in the airbag. You have too little resistance. Possible there is a short somewhere in the wiring? A wrong air bag installed? A failed airbag igniter?
  5. Re: Airbag current too high
    Jun 2008
    The Wee County
    Quote Originally Posted by bearthebruce View Post
    Not strictly true if the additional resistor was fitted in parallel with the resistance of the airbag due to parallel paths the current would indeed increase
  6. Re: Airbag current too high
    Ambler, PA, USA
    You are correct. If they put a resistor in parallel with the igniter, it would draw more current. Why would they shunt current around the igniter? Are you aware of a precedent for doing this?
  7. Re: Airbag current too high
    Jun 2008
    The Wee County
    What I know about airbags and their associated components could be written on the back of a postage stamp.
    I was simply pointing out that sometimes more equals less if you get my drift.
    Have a nice day
  8. Re: Airbag current too high
    Ambler, PA, USA
    I'm no expert on airbags either. But having worked with electric heating devices, I can't think of a reason I would ever shunt the current around the igniter. Ah well, Ian will have to figure it out from here. We're not sitting by the car! (and I'm a bit far away to trouble shoot it!)
  9. Re: Airbag current too high
    Thanks for the imput guys in the meantime will have a look to see if i can find a resistor
  1. Current Motoring petitions...
    By Sam in forum Chat - Completely Off Topic
    Last Post: 28-08-2008, 11:51 AM
  2. current draw?
    By gregomega in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 11-06-2008, 04:24 PM
  3. Current F1 season - will it be a classic?
    By chris555 in forum Chat - Completely Off Topic
    Last Post: 28-04-2008, 07:32 PM
  4. vw golf 1988, no current from ignition coil?
    By Nelson in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 10-12-2006, 10:50 AM
