Thread: Golf mk2 16v starting
  1. Unhappy Golf mk2 16v starting
    HI, i have a mk2 16v. I have recently had a 2.0l 6a bottom end fitted. The problem i am experiencing is that when you start it up you need to give it a some gas. Sometimes its starts first time when i give it some gas and others takes a bit more time before it fires up.
    I have also noticed that when i drive the car for say over 8 miles so the engine is up to temperature, and i stop and turn the engine off, then try to start it up straight away its very difficult, and its like all the power has been drained, but if i leave it for some time then its ok.
    Do you have any idea whats going on here? cheers
  2. Re: Golf mk2 16v starting
    134 Post(s)
    2007 Post(s)
    It sounds as though it has not been set up correctly.
    The locking up sensation is something that always happens with 9A bottom ends in a KR install when hot and can be very embarrassing if you stall it in traffic. You need to have a more powerful starter fitted as the original 0.9Kw item is not enough, you need a 1.1Kw starter. What I do is get a second hand Golf 3 TD starter and swap over the solenoid on top as the starter on the 16v has an output for the cold start valve that the TD starter lacks.
    As a matter of interest, check your starter has a black wire connected to the terminal directly behind the radiator and in front of the tick cable from the battery.
  1. Please Help Mk IV Golf not starting
    By Dylan323 in forum Golf MK4 - 1999 - 2004
    Last Post: 26-11-2008, 09:33 PM
  2. Please Help MK4 Golf Not Starting....
    By nizzex in forum Golf MK4 - 1999 - 2004
    Last Post: 04-07-2008, 09:10 PM
  3. HELP!! Non starting golf gti 16V
    By peterhall617 in forum Golf MK3 - 1993 - 1999
    Last Post: 05-04-2008, 11:26 PM
  4. mk3 golf not starting
    By fraze in forum Golf MK3 - 1993 - 1999
    Last Post: 20-01-2008, 09:21 PM
  5. Golf Mk4 Starting
    By balou in forum Golf MK4 - 1999 - 2004
    Last Post: 28-11-2007, 08:22 PM
