Thread: mk2 Golf gti 16v will not start
Results 1 to 9 of 9
  1. Unhappy mk2 Golf gti 16v will not start
    Nov 2008
    Hi my mk2 Golf gti 16v will not start. It was fine yesterday after 200 miles of driving and nothing for the two months I've had the car, then today it is just turning over and wont fire. there is spark and the fuel pump seems OK. It seems like the immobilizer, I've disconected then re-connected the battery to re-set this, and no joy. Any ideas?
  2. Re: mk2 Golf gti 16v will not start
    Jul 2007
    have you try your spare key? you need to get it plugged in to see if any fault codes, where abouts are you?
    andy
  3. Re: mk2 Golf gti 16v will not start
    hiya ..i dont think it will be the immo if you are getting a spark and fuel ?
    if you have a rev counter see if it moves when cranking
    also check the timing belt as it may have slipped or snapped
    also advise having the codes read .
  4. Re: mk2 Golf gti 16v will not start
    Dec 2008
    East Preston, West Sussex
    Mk2 Golf 16v won't have any codes as there is no diagnostic socket...back to basics.
    There was also no factory immobiliser, there may have been a very basic alarm at some point offered.
    The chances are that if you have an immobiliser it is definately aftermarket, but as suggested it is unlikely that this is the problem as you are getting spark and fuel.
    Is your distributor cap and rotor arm OK? have they been replaced recently?
    Do you have a VW specialist local to where you live?
    John
    2005 A4 B6 Avant 1.9 TDI 130 Sport (6)
  5. Re: mk2 Golf gti 16v will not start
    are you sure they don't have the 2x2 diagnostic port ? what year ?
  6. Re: mk2 Golf gti 16v will not start
    Dec 2008
    If this is a Mk2 16v then I am 99.9% sure there is no diagnostic capability, and in almost 20 years around mk2's I haven't seen one with it. The USA market models may be different but if we are talking about a UK/European one that is what I am basing it on.
    The Mk3 GTI 16v is a different animal, as this had dagnostic capabilities build in from the start.
    John
  7. Re: mk2 Golf gti 16v will not start
    my apologies . i thought they were very well into the diagnostic before then ?
  8. Re: mk2 Golf gti 16v will not start
    Jan 2009
    towcester northants
    Quote Originally Posted by racin snake View Post
    just to let you know mk2 16v golfs suffered from bad engine earths causing the car to turn over but not start engine ecu reqs more than 10 volts to work properly clean main earth to gearbox and the one below battery
  9. Re: mk2 Golf gti 16v will not start
    I just wanted to resurrect this post because I too have a Mk2 16V that won't start after 12 months in the garage. Never had this problem previously. I'm suspecting the fuel pump because when I loosen the feed into the metering unit I only seem to be getting residue fuel coming out. There is power to the fuel pump but I can't hear it running. The plugs also aren't wet after prolonged attempts to start. All suggesting a dead fuel pump.
    The 3 Phillips head screws that secure the fuel pump are very rusty so not easy to remove lying on my back on the garage floor!
    Any suggestions would be gratefully welcomed........
  1. Please Help Golf TDI won't start
    By paghef in forum Golf MK4 - 1999 - 2004
    Last Post: 20-12-2008, 09:44 PM
  2. Please Help golf mk3 gti won't start !!!!!!
    By saint_78 in forum Golf MK3 - 1993 - 1999
    Last Post: 06-10-2008, 09:23 PM
  3. Please Help '97 Golf VR6 will not start.
    By VR6350 in forum Golf MK3 - 1993 - 1999
    Last Post: 15-05-2008, 01:10 PM
  4. Golf 3 gti 8v doesn't start at all
    By enimatek in forum Golf MK3 - 1993 - 1999
    Last Post: 19-10-2007, 01:27 AM
  5. golf mk4 cant start
    By amalawi in forum Golf MK4 - 1999 - 2004
    Last Post: 11-11-2006, 02:58 PM
