Thread: Boot Trim removal
Results 1 to 10 of 15
  1. Boot Trim removal
    Nov 2008
    Hi!
    My name is Sergio and I’m new in this forum. I own a 1997 audi A4 1.9 tdi avant and I’m having some problems with the rear window wiper. Can any one tell me how to remove the boot lid trim? I can only see two screws.
    Thank in advance for your help.
    Best Regards
    Sérgio
  2. Re: Boot Trim removal
    Aug 2007
    Aberdeen
    Undo all visible screws, and the trim is held on by clips.....so "gently pull".....aka yank i off!
    The clips are metal but held on with plastic so make sure you dont snap the plastic when you pull it off or you will have trouble clipping it back on.
    Tez
    Just sold my MINI, and now own a 1996 A4 Avant 1.9TDI, also proud owner of a 1971 mini
  3. Re: Boot Trim removal
    Nov 2008
    Ok! Thanks!
    I can only see 3 screws. Are there any more?
    Best Regards
    Sérgio
  4. Re: Boot Trim removal
    Aug 2007
    Aberdeen
    Quote Originally Posted by scristina View Post
    Ok! Thanks!
    Best Regards
    Sérgio
    No, I think thats it although in all fairness my boot trim near enough fell off due to the oversized speakers the last owner had (badly) fitted into it!
  5. Re: Boot Trim removal
    Nov 2008
    LOL
    I'll remove the trim today to see if the problem is just a loose water tube or if I have to remove the windscreen motor for disassembly.
  6. Re: Boot Trim removal
    Aug 2007
    Aberdeen
    Good luck with that
  7. Re: Boot Trim removal
    Dec 2007
    Leeds
    hi sergio,
    is it that the screenwash is not spraying? if so, check in the cubby hole on the right hand side of the car (as you look into the boot) where the emergency warning triangle is. there is a join in the pipe that comes undone. in freezing weather last year, mine froze and when i tried to use, it just split. as you look in the cubby hole, look in the top left area. the bottom of this cubby hole was drenched with screenwash when i looked in.
    hope this helps. the pipe should just push together again.
  8. Re: Boot Trim removal
    Nov 2008
    HI!
    Thanks for all your helpful comments. I've removed the boot trim and realized the water tube was loose near the windscreen motor. Or so I thought.
    I don’t know how it’s supposed to be, but I could not reconnect the water tube again. In the water entrance there was a black plastic part attached and the water tube was loose and the tube did not fit with the referred plastic part. Strange!!!
    I got a small tube that fitted in the water inlet and tube and glued all together. At least for now it works. I don’t know for how long…
  9. Re: Boot Trim removal
    Aug 2007
    Aberdeen
    Quote Originally Posted by routers77 View Post
    The WHAT?! haha
    your car must be posher than mine!
  10. Re: Boot Trim removal
    Dec 2007
    Leeds
    nice one Mini Mad!
    if your feeling left out http://cgi.ebay.co.uk/GENUINE-AUDI-A...1%7C240%3A1318
  1. Trim removal
    By SneakyMcC in forum Golf MK3 - 1993 - 1999
    Last Post: 15-03-2008, 02:33 PM
  2. Trim removal
    By papalion in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-02-2008, 03:52 PM
  3. A4 Avant B6 Boot Trim removal
    By TheMatador in forum Audi A4 - Archive Topics
    Last Post: 17-12-2007, 06:27 PM
  4. How do I get the boot trim out?
    By BarryD in forum 80 - 90
    Last Post: 21-05-2007, 01:47 PM
  5. Greetings... Boot trim question.
    By judderman in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 20-03-2007, 06:24 PM
