I've just changed the Timing belt on my 2003 Passat & have set it to the correct TDC position using VAG tools. The engine turns over but will not start. There no clunking sound so the valve position I guess is ok.
I suspect one of the sensors may be playing up when I moved the lock carrier assembly. Has anyone got any ideas.
(I'm at the stage of towing it to the garage)
