Thread: Can I get these bushes / Mounts? What do they do? Where can I get them from?
  1. Question Can I get these bushes / Mounts? What do they do? Where can I get them from?
    Sep 2008
    I have just had a service done on my car and been informed that the following things need to be changed sooner rather than later.
    1.FRONT TOP MOUNTS
    2.O/S/F TIE ROD ARM DUE TO EXCESSIVE PLAY
    3.REAR BUMP STOPS SPLIT (found these parts)
    4.O/S/F LOWER ARM BUSHES HAVE EXCESSIVE PLAY (is this linked to item 2 and can I just replace the bushes or do I have to do the whole lot?)
    5.REAR AVEL BUSHES WORN (what the hell is an AVEL bush)
    6.DOG BONE MOUNT BUSH WORN ( I don’t even own a dog!!)
    Don’t panic a friend of mine will be fitting them with me.
    Thanks in advance
    Mat
  2. Re: Can I get these bushes / Mounts? What do they do? Where can I get them from?
    7 Post(s)
    You can replace all the bushes separately except those on the anti-roll bar drop links.
    For you, it may work out cheaper to buy a new set of lower arms rather than attempt to fit the bushes to them unless your mate is fairly handy.
    If you do change the lower arm bushes, only the flat one will be knackered as more than likely, in which case replacing them with items off an Audi TT or Leon Cupra are better, they are solid bushes as opposed to the standard voided ones and tighten up the front end nicely.
  3. Re: Can I get these bushes / Mounts? What do they do? Where can I get them from?
    Sep 2008
    Are you able to provide me with links to each part or part numbers. Sorry for asking!!!
  4. Re: Can I get these bushes / Mounts? What do they do? Where can I get them from?
    7 Post(s)
    Quote Originally Posted by MathewRB View Post
    Nope !
    You can use google etc just as well as I can !
  5. Re: Can I get these bushes / Mounts? What do they do? Where can I get them from?
    Sep 2008
    I di duse google it got me here
  6. Re: Can I get these bushes / Mounts? What do they do? Where can I get them from?
    Apr 2007
    Didn't you notice any deterioration in handling etc before you had the service? There's an awful lot of items to be replaced on your list!
  7. Re: Can I get these bushes / Mounts? What do they do? Where can I get them from?
    Sep 2008
    I have noticed nothing I think part of it is the garage trying its luck!!!
  1. Please Help Top Mounts
    By Volk in forum Bora - 1998 - 2005
    Last Post: 09-07-2008, 11:42 PM
  2. Springs and Mounts
    By TDiBoraSam in forum Bora - 1998 - 2005
    Last Post: 06-05-2008, 06:57 PM
  3. Strut Top Mounts
    By sdk778 in forum 80 - 90
    Last Post: 31-03-2008, 02:35 PM
  4. suspension mounts help please
    By paulgti in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 27-05-2007, 03:21 PM
  5. engine mounts
    By panther in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 19-05-2007, 06:25 PM
