Thread: A Plug/Pin has melted - what's it called?
  1. Question A Plug/Pin has melted - what's it called?
    Passat (Estate - TDi 1.9 - Year: 2004)
    The plug unit that sits adjacent to the bonnet lock, at the top of the radiator housing HAS MELTED.
    There are two small pins/connectors (about 5mm in length).
    You can still unplug the pins - and plug back in, but the plastic has melted.
    Does anyone know what this plug is called - and if at all possible what it's function is?
    I will be posting other problems that might be related to this - i.e.;
    Intermittent fault which cuts the engine dead.
    Thanks in advance.
    Stephen
  2. Re: A Plug/Pin has melted - what's it called?
    135 Post(s)
    2043 Post(s)
    That is the bonnet switch but why has it melted? I have never seen that happen.
  3. Re: A Plug/Pin has melted - what's it called?
    Sep 2008
    Birmingham
    These switch at Earth don't they? If so it must be shorting to a live somewhere.
  4. Re: A Plug/Pin has melted - what's it called?
    135 Post(s)
    2043 Post(s)
    Yes it is and the output goes to the convenience unit and the dash.
  5. Re: A Plug/Pin has melted - what's it called?
    Sep 2008
    Birmingham
    That sounds like a big can of worms could open.
  1. melted spark plug
    By kevmac1 in forum Audi A3 - Archive Topics
    Last Post: 10-11-2008, 07:24 PM
  2. Should the mk6 be called the mk5.1?
    By GarJE in forum Golf MK6 - 2009 - 2013
    Last Post: 21-09-2008, 03:40 AM
  3. Alhambra blower failed and fuse melted
    By kester_holmes in forum Alhambra
    Last Post: 27-08-2007, 06:42 PM
  4. What is it called
    By TomClarke in forum Chat - Anything with wheels
    Last Post: 11-07-2007, 09:27 AM
  5. What is this called?
    By radneo in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-06-2007, 10:00 PM
