Thread: water leak drivers side on 01 S3 help please
  1. water leak drivers side on 01 S3 help please
    scrossley Guest
    got a serious puddle in drivers side footwell front and back,,,,thought it might of been cracked windscreen causing prob so i changed that and dried it out,,,,next night it rained and the puddle had returned,,,,ive felt the carpet all round the edge and its not damp anywhere,,,,can anybody give me any idea as to where the leak can be coming from,,,any help would be great
  2. Re: water leak drivers side on 01 S3 help please
    southampton
    Hello mate, on my mates leon he had the same problem and it was the seals around the door, but I have also heard that it could be blocked water drains under the scuttle panel, may be worth having a look as leafs and all sorts of things can get stuck down there
    Failure is not an option, It is a privilege reserved only for those who try.
  3. Re: water leak drivers side on 01 S3 help please
    Aug 2007
    On mine it was where the bonnet release cable went through the bulkhead in the driver's footwell that was letting in water.
    Pull back the carpet and follow the cable. There should be a rubber gromet around where the cable goes through the bulkhead - if not then it's likely that's where the water is coming in.
  1. water in drivers side footwell
    By baj25 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-05-2010, 04:48 PM
  2. Water leakage on drivers side
    By hendy00 in forum Golf MK4 - 1999 - 2004
    Last Post: 18-05-2008, 07:21 PM
  3. major water leak problem A4 Drivers side rear footwell soaking wet
    By steve888 in forum Audi A4 - Archive Topics
    Last Post: 17-01-2008, 10:27 AM
  4. Water Leak - Drivers side
    By DanAllkins in forum Golf MK4 - 1999 - 2004
    Last Post: 15-01-2008, 10:12 PM
  5. Audi A4 Avant 1.9 Water Leak Passenger Side Footwell
    By Water Boy in forum Audi A4 - Archive Topics
    Last Post: 13-11-2007, 12:09 AM
