Thread: white smoke from sharan
Hybrid View
  1. Question white smoke from sharan
    Feb 2007
    have read comments posted and will start by changing aux heater glow plug does anyone have advice on how easy it is and whether you need special tools cheers
    Jan 2005
    I dont know if you have done this and I have no idea how it is done but I have the same problem. If you have succeeded in doing it please post a step by step guide. How much does the glow plug cost ? I have disconnected my aux heater as havent got £900 plus to have it changed by main dealer.
  3. Smoky Sharan
    I just dissassembled my aux heater, located under the rear left hand door looking for this glow plug. Seems Volkswagen don't want you to actually get to it so they use very weird Tork screws to keep it locked away. Ended up spraying the inside through the exhaust vent with Silkolene lube oil an then putting it all back together again. When started it was a bit smokey but now it's not smoking. I am hoping the silkolene oil has burned off any muck inside but time and a low temp start will tell.
    I'd thought of a breakers yard replacement cause £900 is just too much for what it is, but seems to be such a common fault that I'd probably only be buying the same trouble.
    Sam
  1. VW Sharan 1.9TDI - smoke from under the car
    By Jay1 in forum Touran - Sharan - Caravelle
    Last Post: 06-09-2009, 06:58 PM
  2. 80 Tdi with a lotta white smoke
    By ghee60 in forum 80 - 90
    Last Post: 03-06-2007, 08:25 PM
  3. White Smoke
    By Speedy in forum Touran - Sharan - Caravelle
    Last Post: 05-01-2007, 11:44 PM
  4. 97 a4 1.8 turbo white smoke
    By spjmm0 in forum Audi A4 - Archive Topics
    Last Post: 31-07-2006, 02:57 AM
  5. Smoke from under 1.9 tdi Sharan
    By mike in forum Touran - Sharan - Caravelle
    Last Post: 22-12-2005, 01:33 AM
