Thread: seat belt tensioner
  1. seat belt tensioner
    hi, does anyone no where the seat belt tensioner is located, apparently it could be in the door pillar or in the seat???? this is why my airbag light is on i have no idea how that effects it? cheers steven
  2. Re: seat belt tensioner
    Jul 2008
    stoke on trent
    which one? fault code should tell you, you might have 2,4 or 5 of them fitted
    front ones are in door pillar, you need to pull top part of b pillar trim off then lower part lifts up and out, id check connections first then try reseting again
    are you sure it was tensioner not igniter fault code
  3. Re: seat belt tensioner
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    Hi Steeevo,It is on the inertia reel,but make sure you disconnect the battery b4 removing the plug on the reel,or if your brave,earth yourself -out for static!!!It could be a poor contact and remove/refitting plug may do it.This cured a similar fault on my seat airbag,high resistance fault.
  4. Re: seat belt tensioner
    hi, if i unplug an re connect it, will the light still show as a fault still or will i need to get it reset to see if it has been resolved. thanks
  5. Re: seat belt tensioner
    Nov 2008
    20 Post(s)
    Hi , it may cure the fault but you`ll never know until you try and clear it unfortunatley,as with Airbag faults,they wont clear until they`ve been interogated by the VAG comp.and attempted cancelling of the fault.
    An independent garage may be cheaper than getting a dealer to read the fault.
    Good luck!
  1. AFN Aux Belt Tensioner
    By OxfordGTI in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-03-2010, 10:42 PM
  2. Question Tensioner belt?
    By tomjj in forum Golf MK5 - 2004 - 2009
    Last Post: 05-01-2009, 11:52 AM
  3. cam belt chain tensioner on seat ibiza
    By Dave Ridley in forum Ibiza - Cordoba
    Last Post: 28-05-2008, 05:41 AM
  4. Alternator belt tensioner
    By j44nty in forum Golf MK3 - 1993 - 1999
    Last Post: 27-05-2008, 09:03 PM
  5. Belt tensioner
    By simonvw in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-10-2007, 07:58 PM
