Thread: Can anyone help bora tdi starting problem
  1. Unhappy Can anyone help bora tdi starting problem
    Nov 2008
    I have 2004 tdi 150 bora which WAS remapped it came up with crank sensor fault an struggled to start, so changed crank sensor and no change except now 2 faults ecu fault so changed crank sensor and sent ecu to lynx now not totally sure what they have done but crank sensor fault gone but ecu fault still there an car still struggling to start, once its runnin it drives great but still has problems starting, its worse when cold though, oh an lynx say there is nothin wrong with ecu even though diagnostics say otherwise can someone please help me.
  2. Re: Can anyone help bora tdi starting problem
    7 Post(s)
    Have you changed the coolant temp sensor ?
    These are very unreliable and fail all the time. It is rare for them to show up a fault code either.
    A nice cheap DIY fix.
  3. Re: Can anyone help bora tdi starting problem
    Nov 2008
    I have changed cooling temp sensor and cam sensor to be sure jus had it started took it for run to warm it up but soon as knocked off wouldn start again.
  4. Re: Can anyone help bora tdi starting problem
    Nov 2008
    What i dont understand is if ecu is ok when tested by lynx y is it still bringing up same fault code when back in car.
  1. V5 Bora hot starting problem
    By pdhamblin in forum New Member Introductions
    Last Post: 20-08-2010, 05:19 PM
  2. bora tdi not starting
    By spannerphobia in forum Bora - 1998 - 2005
    Last Post: 01-02-2009, 06:25 PM
  3. Bora 2.0SE 2000 (x) - Issues with starting
    By manix in forum Bora - 1998 - 2005
    Last Post: 20-12-2008, 05:05 PM
  4. vw bora tdi starting problems
    By gidyon2006 in forum Bora - 1998 - 2005
    Last Post: 21-11-2008, 11:56 PM
  5. vw bora not starting
    By macker61 in forum Bora - 1998 - 2005
    Last Post: 24-10-2008, 10:32 PM
