Thread: crankcase breather filter and valve
  1. crankcase breather filter and valve
    Aug 2007
    Hook Hampshire
    21 Post(s)
    I am in the middle of replacing both these items crankcase filter and EGR valve. I can't seem to get the filter off as its deep in the V. I have removed the fuel pipes, but there are 2 obstacles. The first is a thick solid pipe attached to the bottom of the valve and goes below the turbo and the second is a thinner pipe that seems to feed oil to the turbo.
    Do I need to remove the turbo to get access to the filter and do I need to replace the turbo gaskets. Is there any thing I need to be aware of.
    Thanks.
    Audi A7 3.0TDi 2011 180k miles, engine code CLAB 204bhp 2WD
  2. Re: crankcase breather filter and valve
    london/ UK
    Quote Originally Posted by shabazmo View Post
    Thanks.
    You need to remove the turbocharger...If you have the later engine, then you should have the uprated breather type. The later ones dont clog. To fit the later breather, the oil feed pipe needs removing as well, its only held in place by a single bolt. You can remove the egr pipe to gain acces to the breather but, you will need some flexi head 12mm spanner and it will take really long ! You will also need a stubby 12mm spanner to remove the difficult to reach nut on the turbo....
  3. Re: crankcase breather filter and valve
    Aug 2007
    Hook Hampshire
    21 Post(s)
    Thanks again Adamss, I obviously have the later type. I didn't have to remove the turbo. I got both pipes off. What a pig! The filter looks just like the new one and the egr spring tension and movement feels like new. What a waste of time. Now to put the new parts back on.
    Regards
  1. Golf MK3 crankcase breather very oily...
    By powellcd in forum Golf MK3 - 1993 - 1999
    Last Post: 27-02-2012, 02:26 PM
  2. Crankcase Breather 54 130tdi
    By martuk in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-02-2011, 11:49 PM
  3. Golf 1.4s Crankcase Breather - Oil Consumption - Help!
    By Oldgit in forum Golf MK4 - 1999 - 2004
    Last Post: 14-09-2008, 08:56 PM
  4. Crankcase Oil Breather - 1.4s
    Last Post: 01-09-2008, 06:45 AM
  5. Please Help Crankcase breather hose.
    By Brian Rouse in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-05-2008, 10:37 PM
