Thread: mk4 leaking sunroof
  1. mk4 leaking sunroof
    Nov 2006
    i have a golf mk 4 x reg and i found a puddle of water in the plastic trim under the hand brake. i cant see any visible damage. any ideas??????????
    Quote Originally Posted by rasper05 View Post
    first of all. have you established it is the sunroof at fault? i know its obvious, but it may not be. bes way to tell, get yourself inside the car, get someone to pour some water down and see if it leaks.
    if it does, try and narrow down which side of the sunroof its leaking in from and check the seal, if the seal looks worn/torn/broken, invest in a new seal and get it repaird. if the seal appears fine, try a little vaseline all around the seal, sometimes the sunroof glass will meet but not make an air tite seal. i doubt its anything to do with the pollen filter fault, as you said its in the plastic trim, it wouldnt get ther any other way
  1. mk3 sunroof
    By wilmot in forum Golf MK3 - 1993 - 1999
    Last Post: 17-09-2007, 04:29 PM
  2. solar panel sunroof
    By dexsan in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-05-2007, 06:23 PM
  3. Sunroof Seal
    By Scotty Dave in forum 80 - 90
    Last Post: 15-05-2007, 10:28 PM
  4. Sunroof
    By magsnmartin in forum 80 - 90
    Last Post: 08-05-2007, 03:32 PM
  5. Sunroof
    By san in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 19-02-2007, 03:04 PM
