Thread: Boost Gauge Needle Twitching
  1. Boost Gauge Needle Twitching
    Hi.
    Mk4 Golf GTi T - AGU/KO3 c/w Forge 007P and relocation kit.
    My question is...
    If my Forge 007P was sticking somehow, or if I had a leak somewhere on my relocation kit... could this account for my boost gauge needle twitching (it twitches/shakes rapidly at idle sometimes).
    Also, could this have anything to do with the car cutting out on me do you think?
    Twign
  2. Re: Boost Gauge Needle Twitching
    Sep 2008
    Birmingham
    It'd explain the gauge fluttering but I'd check for a leaky/dislodged vacuum hose for the cutting out.
  3. Re: Boost Gauge Needle Twitching
    Hi.
    Cheers for the response.
    Well I've had a VAG charge system pressure test done... and everything's shown up fine.
    Isn't there a vac hose connecting to the DV? What i'm thinking is... if this were leaking (because I think the DV was disconnected somewhere when the pressure test was done) could this account for both? Coz this would explain how the pressure test missed it I suppose.
    I've spent a fortune trying to figure out what's causing my car to cut out. After cleaning the Forge and still having no look... I'm thinking of removing it and the relocation kit and going back to stock DV just to them both from my list of possible causes.
    Thanks again
    Twign
  4. Re: Boost Gauge Needle Twitching
    Sep 2008
    Birmingham
    Quote Originally Posted by twign View Post
    Hi.
    Thanks again
    Twign
    Yes there is a vacuum line attached to the DV, I suppose this would be the first port of call as it's been moved to fit the 007. Check that it hasn't split whilst fitting or come adrift afterwards.
  1. tdi boost gauge
    By stockportdubfan in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-04-2008, 06:22 PM
  2. Boost Gauge?
    By Golf_TDI-150 in forum Chat - Anything with wheels
    Last Post: 30-03-2008, 11:27 PM
  3. boost gauge
    By webbyturbo in forum Audi A3 - Archive Topics
    Last Post: 13-03-2008, 04:36 PM
  4. boost gauge
    By dave25 in forum Bora - 1998 - 2005
    Last Post: 25-02-2008, 09:51 PM
  5. a3 boost gauge
    By Jimbo1.8t in forum Archive posts
    Last Post: 22-08-2007, 09:14 PM
