Thread: driver display
  1. driver display
    Nov 2008
    Sorry if i`verm in the wrong area (first timer) but need some info about the driver display. I have changed the front brake pads but the display still indicates the pads need changing. the brakes are good at the back. Is there a way off removing the symbol
  2. Re: driver display
    Sep 2008
    North Cheshire
    It is in the wrong area as VAGCOM relates to on-board diagnostics for which you will need some software (VAGCOM) and a suitable cable.
    BUT...
    It sounds like you have replaced the pads and not connected up the brake wear circuit.
    On the LHS front inner brake pad there should have been two wires connecting it to a socket on the suspension. If the replacement pads didn't have this wire then you need to snip the old wire from the old pads, strip it back a bit, twist them together and cover with insulating tape (or similar) then plug back into the socket. this will keep the light off - but it does mean you won't get indication of future brake wear.
  3. Re: driver display
    Nov 2008
    thanks for the info.
  1. A6 2.4 Driver Display Screen Faulty
    By Paulpro in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 17-04-2009, 08:50 AM
  2. Audi A3 Driver display
    By ezpixs in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 16-05-2008, 10:08 PM
  3. Driver Information Display
    By JPMCT in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 21-11-2007, 09:25 AM
  4. missing lines on the mpg/cd radio driver display between
    By maliceinwonderland in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-07-2007, 09:03 PM
  5. A6 2.4 Avant Yr 2000 Driver Display Fault
    By Paulpro in forum Chat - Completely Off Topic
    Last Post: 05-02-2007, 02:33 PM
